08-05-2021, 10:39 | #1 (permalink) |
Crazy Poster Join Date: Mar 2010 Location: china
Member: 1258908 Status: Offline Thanks Meter: 4 | VIVO PD2057 REDMI10PRO After the FlashIMEI00000000000000 Selected model: Vivo UNKNOWN Operation: Flash (Download only) Software version: 2.3 Parse scatter file... OK Load Rom Images... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0996 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6853] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM54 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0996 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6853] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xF009B1B3, 0x54CB93DF, 0x1A2DD8AD, 0x14D2A98C Get Chip ID... [MT6853] Get SOC ID... [711470FD3EC3A3C9A5A9E6E7F1C895199AF2A0ECC6F56A10E6 FAFCBCE8803C25] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [30] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): KM8V8001JM-B813 (1900) Load EMI config from preloader... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : KM8V8001JM-B813 UFS_FWVER : 1900 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Get scatter info... OK Check USB status... USB_HIGH_SPEED Get scatter info... OK Verify scatter file... OK Do NAND BMT remark... OK Setup download info... OK Get partition table catagory... OK [GPT] Read mirror partition table... OK Generate mirror partition table... OK Download mirror partition table... OK Read major partition table... OK Generate major partition table... OK Download major partition table... OK Download "preloader"... OK Download "recovery"... OK Download "vbmeta"... OK Download "vbmeta_system"... OK Download "vbmeta_vendor"... OK Download "survival"... OK Download "cust"... OK Download "vgc"... OK Download "storage"... OK Download "efuse"... OK Download "md1img"... OK Download "spmfw"... OK Download "audio_dsp"... OK Download "pi_img"... OK Download "dpm_1"... OK Download "dpm_2"... OK Download "scp1"... OK Download "scp2"... OK Download "sspm_1"... OK Download "sspm_2"... OK Download "mcupm_1"... OK Download "mcupm_2"... OK Download "cam_vpu1"... OK Download "cam_vpu2"... OK Download "cam_vpu3"... OK Download "gz1"... OK Download "gz2"... OK Download "lk"... OK Download "lk2"... OK Download "boot"... OK Download "logo"... OK Download "dtbo"... OK Download "tee1"... OK Download "tee2"... OK Download "super"... OK Download "cache"... OK Download "userdata"... OK Flashing done! REDMI10PRO Selected model: Xiaomi UNKNOWN Operation: Flash (Upgrade) Software version: 2.3 Parse scatter file... OK Load Rom Images... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0950 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6893] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM54 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0950 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6893] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x5DD28880, 0x5EBBDDEE, 0xF2D149AD, 0xA7D67A38 Get Chip ID... [MT6893] Get SOC ID... [8876F86E33077EE6ADDC056AF50580B03F7706CD35D8B7B0F9 5CA7FF1B3D3DA4] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [31] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): HN8T05BZGKX015 (A043) Load EMI config from preloader... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : HN8T05BZGKX015 UFS_FWVER : A043 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Get scatter info... OK Check USB status... USB_HIGH_SPEED Prepare list for upgrade... OK Check upgrade list... OK Prepare format list... OK Prepare final partition list... OK Read partition "preloader"... OK Read partition "nvcfg"... OK Read partition "persist"... OK Read partition "protect1"... OK Read partition "protect2"... OK Read partition "proinfo"... OK Read partition "nvram"... OK Verify checksum... OK Format UFS_LU2 partition( 0x00008000..0x02D87FFF )... OK Format UFS_LU2 partition( 0x04D88000..0x0DD87FFF )... OK Format UFS_LU2 partition( 0x13000000..0x389FFFFF )... OK Format UFS_LU2 partition( 0x38D00000..0x38D7FFFF )... OK Format UFS_LU2 partition( 0x3CD80000..0x1DC9FF7FFF )... OK Get scatter info... OK Verify scatter file... OK Do NAND BMT remark... OK Setup download info... OK Get partition table catagory... OK [GPT] Read mirror partition table... OK Check partition table layout changed... OK Read major partition table... OK Check major partition table layout changed... OK Download "preloader"... OK Download "vbmeta_a"... OK Download "vbmeta_system_a"... OK Download "vbmeta_vendor_a"... OK Download "md1img_a"... OK Download "spmfw_a"... OK Download "audio_dsp_a"... OK Download "pi_img_a"... OK Download "dpm_a"... OK Download "scp_a"... OK Download "sspm_a"... OK Download "mcupm_a"... OK Download "cam_vpu1_a"... OK Download "cam_vpu2_a"... OK Download "cam_vpu3_a"... OK Download "gz_a"... OK Download "lk_a"... OK Download "boot_a"... OK Download "dtbo_a"... OK Download "tee_a"... OK Download "mitee_a"... OK Download "efuse"... OK Download "logo"... OK Download "super"... OK Download "cust"... OK Download "rescue"... OK Download "userdata"... OK Write file "nvcfg.bin"... OK Write file "persist.bin"... OK Write file "protect1.bin"... OK Write file "protect2.bin"... OK Write file "proinfo.bin"... OK Write file "nvram.bin"... OK Flashing done! |
