05-21-2021, 16:35 | #1 (permalink) |
Freak Poster Join Date: Apr 2012 Location: gsm
Member: 1750690 Status: Offline Thanks Meter: 70 | vivo s1 pd1913f imie repair failed Operation: Repair Software version: 1.11 Parse scatter file... OK Load Rom Images... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM100 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x4D7C2F39, 0xF51850C3, 0x046FFC5A, 0xE1CCE40D Get Chip ID... [MT6768] Get SOC ID... [A527B4A6362D1ADFE1C9FE1CEAA8334518200554E1A850DCA1 FD11F79192D267] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [26] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100445636444D4202E7CE6AE2B6A5 Load EMI config from preloader... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100445636444D4202E7CE6AE2B6A5 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x1D1EC00000 (116.48Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Get scatter info... OK Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Reading security from phone... OK IMEI 1: 86xxxxxxxxxxxxxx IMEI 2: 86xxxxxxxxxxxxxx Set new IMEI to: IMEI 1: 35xxxxxxxxxxxxxx IMEI 2: 35xxxxxxxxxxxxx Searching security key... key not found bootloader already unlocked...... |
05-21-2021, 18:59 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | Quote:
we will check the problem with this firmware and tomorrow will give you answer. | |
The Following User Says Thank You to blang For This Useful Post: |
05-22-2021, 13:44 | #3 (permalink) | |
No Life Poster Join Date: Nov 2007 Location: Indonesia Raya
Member: 636569 Status: Offline Thanks Meter: 192 | Quote:
how to continuation of this problem? | |
05-22-2021, 14:53 | #7 (permalink) | |
Member: 1750690 Status: Offline Thanks Meter: 70 | Quote:
this phone is second one all phones says key not found Selected model: Vivo PD1913F (Y7s) Operation: Repair Software version: 1.11 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM100 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x42095559, 0xB8073CDD, 0x67402AFC, 0x9EE0112E Get Chip ID... [MT6768] Get SOC ID... [51A4988566E82DFCA72FEF83DD6368E985BB9CF99E7AE23D7E E866686E85BE8D] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [26] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100445636444D420232036AD017AD Load EMI config from database [DB VER: 102 DB DATE: 05-19-2021] OK [1] Trying EMI [803F67B3, 1BB1F176, AF66D99A, 703B5CDE, C41C94FB, F5628DA3, 8EE5A8E8, 4A42877C, F83EEC01] Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100445636444D420232036AD017AD EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x1D1EC00000 (116.48Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Reading security from phone... OK IMEI 1: 86xxxxxxxxxxxxxx IMEI 2: 86xxxxxxxxxxxxxx Set new IMEI to: IMEI 1: 356698977979773 IMEI 2: 356698977979567 Searching security key... key not found | |
The Following User Says Thank You to Universal957 For This Useful Post: |
