05-07-2022, 12:28 | #1 (permalink) |
Freak Poster Join Date: Feb 2017 Location: Pakistan
Member: 2680797 Status: Offline Thanks Meter: 44 | Vivo V2111 Y21 2022-03-01 imei repair without test point done... [Solved] Thanks Team, Code: Selected model: Vivo V2043 (Y20 2021) Operation: Repair Software version: 3.4 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM30 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM30 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xEFBC5493, 0x18E48B3F, 0x8D5C1363, 0x23A60C16 Get Chip ID... [MT6765] Get SOC ID... [598F7B4FBD304E6DD0427B812C9568B97CB80C84D7992A3C7C3993A7B9BC5A90] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100445036444142028CE4DC3AA8A1 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100445036444142028CE4DC3AA8A1 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0E8F800000 (58.24Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : vivo Product Manufacturer : vivo Product Model : V2111 Product Name : 2111N Product Device : 2111 Product Board : k65v1_64_bsp Board Platform : MTK6765 Build ID : RP1A.200720.012 Build Date : Fri Mar 11 20:30:25 CST 2022 Display ID : Funtouch OS 11.1 Global Security Patch : 2022-03-01 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1.4.5 Reading security from phone... OK IMEI 1: 862XXXXXXXXXX97 IMEI 2: 862XXXXXXXXXX89 Set new IMEI to: IMEI 1: 354XXXXXXXXXX39 IMEI 2: 354XXXXXXXXXX88 Searching security key... found! [3] Writing security to phone... OK Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Read IMEI... OK IMEI 1: 862XXXXXXXXXX97 IMEI 2: 862XXXXXXXXXX89 Repairing IMEI... IMEI 1: 354XXXXXXXXXX39 IMEI 2: 354XXXXXXXXXX88 Write IMEI [NVDATA]... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! |
The Following 3 Users Say Thank You to mrehan991 For This Useful Post: |
05-09-2022, 13:21 | #2 (permalink) | |
Freak Poster Join Date: Dec 2017 Location: australia Age: 25
Member: 2793383 Status: Offline Thanks Meter: 57 | Quote:
The Following 4 Users Say Thank You to fmshckr For This Useful Post: |
12-28-2023, 14:21 | #7 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: Sindhu Desh Age: 36
Member: 199814 Status: Offline Thanks Meter: 1,960 | Quote:
