03-15-2023, 21:26 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | Vivo x70 pro not connecting on preloader mode [Solved] Selected model: Vivo PD2135 (X70 Pro) Operation: Read Flash Info Software version: 4.7 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone in PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM_V1633 (Android),usb2ser.sys,3.0.1504.0] Device found at COM34 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 0950 Get sec config... OK [00000005] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 LibUSB installed Detect chip [MT6893] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Preloader exist. Skip connection verification. Get ME ID... OK ME_ID = 0xE77C7360, 0x1451D40F, 0xAFCF6F62, 0x50F390C2 Load DownloadAgent... OK Search DA... OK [12] Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [PRELOADER] Preloader alive. Skip initializing external RAM Get device info... OK UFS CID (FW VER): KLUEG8UHDC-B0E1 (0600) Advanced Bypass Security... open error |
03-28-2023, 13:04 | #5 (permalink) |
Junior Member Join Date: Sep 2018
Member: 2862233 Status: Offline Sonork: 2115576 Thanks Meter: 0 | Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone in PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM_V1632 (Android),usb2ser.sys,3.0.1504.0] Device found at COM26 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 0950 Get sec config... OK [00000005] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 LibUSB installed Detect chip [MT6893] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Preloader exist. Skip connection verification. Get ME ID... OK ME_ID = 0xC2DBBE7A, 0xE7250CE6, 0xBEA372AC, 0xBE05E68A Load DownloadAgent... OK Search DA... OK [12] Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [PRELOADER] Preloader alive. Skip initializing external RAM Get device info... OK UFS CID (FW VER): KLUEG8UHDC-B0E1 (0600) Advanced Bypass Security... open error Selected model: Vivo V2105 (X70 Pro 5G) Operation: Read Flash Info Software version: 4.8 |
