07-16-2021, 13:40 | #1 (permalink) |
No Life Poster Join Date: Apr 2021 Location: GSM AFRICA TEAM (SA)
Member: 2986985 Status: Offline Thanks Meter: 163 | Vivo (Y12) PD1901BF Password Remove DONE Selected model: Vivo PD1901BF (Y12) Operation: Wipe Partitions Software version: 2.1 Erasing of partitions can damage your device. Make sure that you have a backup created. Continue? YES Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM4 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x37B99204, 0xF8B31C59, 0x0E6DFC5C, 0xA456AB29 Get Chip ID... [MT6765] Get SOC ID... [0FD4D721DFADD43F7ACD4AA5B964712EF7439F86248CBD5876 51ED10EDBC3420] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [23] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x90014A68433861503E0333254CD2173F Load EMI config from database [DB VER: 162 DB DATE: 07-09-2021] OK [1] Trying EMI [BCFFEFAA, 17C83B21, 1BB1F176, 6B6AF861, C40777C0, 2826AF0D, 92392267, 9C47C7D7, 4C76F2A3, CA96141A, E395B304, EB371E79, F6969C3D, AEE35A5C, CCFE52E9, F6A9B5C6, 3044B25D, B772E8DA, 40457DA8, 4ECF8C5A, 667E0B28, D6C7319B, D8F5BD39] Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x90014A68433861503E0333254CD2173F EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0001000000 (16,00Mb) EMMC_USER : 0x0E8F800000 (58,24Gb) RAM INFO: INT_SRAM: 0x000003A000 (232,00Kb) EXT_RAM : 0x00C0000000 (3,00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Format "cache" partition... OK Format "userdata" partition... OK Format Partitions done! |
