03-19-2023, 17:19 | #1 (permalink) |
Banned Join Date: Jun 2008 Location: Algérie
Member: 784101 Status: Offline Sonork: 92737 Thanks Meter: 39 | Vivo V2124(Y76 5G) android 13 Dead after reading info with Pandora 4.8 Here the log: Selected model: Vivo V2124 (Y76 5G) Operation: Read Flash Info Software version: 4.8 Work ID: 1028947 Connect phone in PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM (Android),usb2ser.sys,3.0.1504.0] Device found at COM64 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 0989 Get sec config... OK [00000005] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Install LibUSB... OK Waiting for device... OK Open port... OK Detect chip [MT6833] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Preloader exist. Skip connection verification. Get ME ID... OK ME_ID = 0x46D2B946, 0xE29A23DF, 0x376814F1, 0x8D632254 Load DownloadAgent... OK Search DA... OK [11] Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [PRELOADER] Preloader alive. Skip initializing external RAM Get device info... OK UFS CID (FW VER): KM8V9001JM-B813 (0600) Advanced Bypass Security... OK Send preloader... OK Load DownloadAgent... OK Search DA... OK [14] Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : KM8V9001JM-B813 UFS_FWVER : 0600 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Checking USB status... USB_HIGH_SPEED Read partitions info from phone... error(STATUS_PARTITION_TBL_NOT_EXIST) Read Flash Info done! Device dead after this not even recognized by pc with or without battery connected. |
03-19-2023, 19:32 | #3 (permalink) |
Member: 784101 Status: Offline Sonork: 92737 Thanks Meter: 39 | Ok i have been trying it for over 2hours now playing the TP around the volume button still no sign of any communication to the PC. Any advice on what else to try as for the battery is is fully charged? |
03-20-2023, 16:46 | #6 (permalink) | |
Member: 784101 Status: Offline Sonork: 92737 Thanks Meter: 39 | Quote:
What do you advice to try at this stage? | |
03-21-2023, 20:26 | #10 (permalink) |
Member: 784101 Status: Offline Sonork: 92737 Thanks Meter: 39 | Here 2 pictures please let me know if you will need more then these[ATTACH]20230321_211740.jpg[/ATTACH] |
03-21-2023, 20:45 | #11 (permalink) | |
