02-06-2023, 12:54 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Barisal Age: 44
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | OPPO A57 4g cph 2387 - sim-unlock.Mdm unlock ok [Done] Selected model: OPPO CPH2083 (Oppo A12) Operation: Unlock network Software version: 4.6 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0] Device found at COM7 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Waiting for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0] Device found at COM7 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get sec config... OK [000000E0] Active sec flags: [] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x9C921FF0, 0x81BB7DA9, 0x6FBD2734, 0x800BF914 Get Chip ID... [MT6765] Get SOC ID... [A9B90D8D1AFAB8CB31F52C380421BC9ED67810383CA3A47C0B E659B638D6CC7E] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Checking preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100435554423432026C12E2D459F9 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_CNAME: CUTB42 EMMC_ID : 0x150100435554423432026C12E2D459F9 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0E8F800000 (58.24Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Checking USB status... USB_HIGH_SPEED Read partitions info from phone... OK Checking A/B state... OK [B] Read security partition from phone... OK Read security files... OK Read security files... OK Read lock info... OK Read partition "nvdata"... OK Read NVDATA files... OK Read IMEI... OK Unlock... OK [DF1, DF2, GB1, GB2, SM] Write lock info... OK Write security partition to phone... OK Network Unlock done! All credit goes to Pandora’s box Team Last edited by Z3X; 02-06-2023 at 12:59. |
The Following 2 Users Say Thank You to Dooha_Bd For This Useful Post: |
02-25-2023, 15:56 | #2 (permalink) |
Freak Poster Join Date: Aug 2007 Location: JO-JO-JO Age: 40
Member: 576742 Status: Offline Thanks Meter: 20 | Software version: 4.6 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM92 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Waiting for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM92 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get sec config... OK [000000E0] Active sec flags: [] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xAAE0D437, 0x3FA91C19, 0xCAB7468C, 0xB066E603 Get Chip ID... [MT6765] Get SOC ID... [B6E0E018F15AF1A2E5715EF0ADC64BD20800F9280FE2D0A11F 9181AC21C69BC3] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Checking preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100445554423432029D7EC0609925 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_CNAME: DUTB42 EMMC_ID : 0x150100445554423432029D7EC0609925 EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0001000000 (16,00Mb) EMMC_USER : 0x1D1EC00000 (116,48Gb) RAM INFO: INT_SRAM: 0x000003A000 (232,00Kb) EXT_RAM : 0x0100000000 (4,00Gb) Checking USB status... USB_HIGH_SPEED Read partitions info from phone... OK Checking A/B state... OK [A] Read product info... error(3) Read security partition from phone... OK Read security files... OK Read security files... OK Read lock info... error(1) Selected model: OPPO CPH2077 (Oppo A12) Operation: Unlock network Software version: 4.6 |
02-25-2023, 15:56 | #3 (permalink) |
02-25-2023, 17:05 | #4 (permalink) | |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,065 | Quote:
02-25-2023, 19:26 | #5 (permalink) |
Member: 576742 Status: Offline Thanks Meter: 20 | Selected model: OPPO CPH2083 (Oppo A12) Operation: Unlock network Software version: 4.6 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM92 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Waiting for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM92 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get sec config... OK [000000E0] Active sec flags: [] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xAAE0D437, 0x3FA91C19, 0xCAB7468C, 0xB066E603 Get Chip ID... [MT6765] Get SOC ID... [B6E0E018F15AF1A2E5715EF0ADC64BD20800F9280FE2D0A11F 9181AC21C69BC3] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Checking preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100445554423432029D7EC0609925 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_CNAME: DUTB42 EMMC_ID : 0x150100445554423432029D7EC0609925 EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0001000000 (16,00Mb) EMMC_USER : 0x1D1EC00000 (116,48Gb) RAM INFO: INT_SRAM: 0x000003A000 (232,00Kb) EXT_RAM : 0x0100000000 (4,00Gb) Checking USB status... USB_HIGH_SPEED Read partitions info from phone... OK Checking A/B state... OK [A] Read security partition from phone... OK Read security files... OK Read security files... OK Read lock info... error(1) |
02-25-2023, 20:30 | #6 (permalink) | |
04-04-2023, 08:31 | #7 (permalink) |
Freak Poster Join Date: Oct 2006 Location: Philippines
Member: 379023 Status: Offline Thanks Meter: 38 | Selected model: OPPO CPH2083 (OPPO A12) Operation: Unlock network Software version: 4.9 Work ID: 1344118 Parse scatter file... OK Load Rom Images... OK Connect phone in BROM/PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM3 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Release testpoint, waiting 2 seconds Advanced Bypass Security... OK Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM3 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get sec config... OK [000000E0] Active sec flags: [] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] LibUSB installed Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x580D31FD, 0x7613BC8A, 0x0F5F300D, 0xB5587A5F Get Chip ID... [MT6765] Get SOC ID... [862983531764AF533A92DF753CEBA1E56A9DB41B2B45171D6C E4A7C0AE1A15F1] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Checking preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x9B01005932503036340059D942078991 Load EMI config from preloader... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_CNAME: Y2P064 EMMC_ID : 0x9B01005932503036340059D942078991 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0E8F800000 (58.24Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Get scatter info... OK Checking USB status... USB_HIGH_SPEED Read partitions info from phone... OK Checking A/B state... OK [B] Read security partition from phone... OK Read security files... OK Read security files... OK Read lock info... error(1) |
04-11-2023, 13:30 | #8 (permalink) | |
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | Quote:
09-21-2023, 13:09 | #12 (permalink) | |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 439 | Quote:
HOW did you connect the phone? For me i press V+ and V- but software wrote UNSUPPORTED below.. | |
09-21-2023, 13:28 | #13 (permalink) | |
Member: 64823 Status: Offline Thanks Meter: 439 | hello i got same PROblem.... Cannot UNLOCK.... Quote:
09-21-2023, 15:30 | #15 (permalink) |
Member: 64823 Status: Offline Thanks Meter: 439 | Hello. I did what you asked for and this is the link: https://drive.google.com/file/d/1ZZi...ew?usp=sharing |
The Following User Says Thank You to zakiyyboss For This Useful Post: |
