06-30-2022, 16:32 | #1 (permalink) |
Freak Poster Join Date: Aug 2009 Location: turkey
Member: 1105442 Status: Offline Thanks Meter: 46 | Xiaomi 21081111RG (11T) faild repair imei [Answered] Operation: Repair Software version: 3.7 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0950 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6893] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM69 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0950 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6893] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xB198172B, 0xCDB28929, 0xE2DB6E6A, 0xA93008A0 Get Chip ID... [MT6893] Get SOC ID... [565D01C48F4AC2EC66E4E325F4ADBAB5217753AF265AD3BA9D 1CAB8BAE3D2DA3] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [19] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): KLUDG4UHDC-B0E1 (0200) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : KLUDG4UHDC-B0E1 UFS_FWVER : 0200 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK [A] Read product info... OK Product Brand : redmi Product Manufacturer : Xiaomi Product Model : missi Product Name : missi Product Device : missi Product Board : agate Board Platform : 6893 Build ID : SP1A.210812.016 Build Date : Fri Feb 18 19:27:07 CST 2022 Display ID : SP1A.210812.016 Security Patch : 2022-01-01 Version SDK : 31 Version Release : 12 Version Codename : REL Firmware Version : V13.0.2.0.SKWMIXM Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Read IMEI... OK IMEI 1: 864540055480925 IMEI 2: 864540055480933 Repairing IMEI... IMEI 1: 199120220630005 IMEI 2: 199120220631110 Write IMEI [NVDATA]... error(1) |
06-30-2022, 17:29 | #4 (permalink) |
Member: 1105442 Status: Offline Thanks Meter: 46 | Selected model: Xiaomi 21081111RG (11T) Operation: Repair Software version: 3.7 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0950 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6893] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM69 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0950 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6893] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xB198172B, 0xCDB28929, 0xE2DB6E6A, 0xA93008A0 Get Chip ID... [MT6893] Get SOC ID... [565D01C48F4AC2EC66E4E325F4ADBAB5217753AF265AD3BA9D 1CAB8BAE3D2DA3] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [19] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): KLUDG4UHDC-B0E1 (0200) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : KLUDG4UHDC-B0E1 UFS_FWVER : 0200 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK [A] Read product info... OK Product Brand : Xiaomi Product Manufacturer : Xiaomi Product Model : agate Product Name : agate Product Device : agate Product Board : agate Board Platform : MT6893 Build ID : RP1A.200720.011 Build Date : Sat Sep 18 21:42:20 CST 2021 Display ID : agate-userdebug 11 RP1A.200720.0 Security Patch : 2021-02-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : FACTORY-AGATE-0918 Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Read IMEI... OK IMEI 1: 864540055480925 IMEI 2: 864540055480933 Repairing IMEI... IMEI 1: 199120220630005 IMEI 2: 199120220631110 Write IMEI [NVDATA]... error(1) |
The Following User Says Thank You to hafeez91 For This Useful Post: |
06-30-2022, 17:29 | #5 (permalink) |
Member: 1105442 Status: Offline Thanks Meter: 46 | Selected model: Xiaomi 21081111RG (11T) Operation: Read IMEI Info Software version: 3.7 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0950 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6893] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM69 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0950 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6893] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xB198172B, 0xCDB28929, 0xE2DB6E6A, 0xA93008A0 Get Chip ID... [MT6893] Get SOC ID... [565D01C48F4AC2EC66E4E325F4ADBAB5217753AF265AD3BA9D 1CAB8BAE3D2DA3] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [19] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): KLUDG4UHDC-B0E1 (0200) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : KLUDG4UHDC-B0E1 UFS_FWVER : 0200 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK [A] Read product info... OK Product Brand : Xiaomi Product Manufacturer : Xiaomi Product Model : agate Product Name : agate Product Device : agate Product Board : agate Board Platform : MT6893 Build ID : RP1A.200720.011 Build Date : Sat Sep 18 21:42:20 CST 2021 Display ID : agate-userdebug 11 RP1A.200720.0 Security Patch : 2021-02-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : FACTORY-AGATE-0918 Read partition "nvdata"... OK Read NVDATA files... OK Read IMEI... OK IMEI 1: 864540055480925 IMEI 2: 864540055480933 Reading IMEI done! |
