03-27-2023, 13:37 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: ...::::GUJRAT::::...
Member: 781860 Status: Offline Thanks Meter: 203 | y76 5g vivo dead after read info. [Answered] Operation: Read Flash Info Software version: 4.8 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone in PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM (Android),usb2ser.sys,3.0.1504.0] Device found at COM36 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 0989 Get sec config... OK [00000005] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 LibUSB installed Detect chip [MT6833] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Preloader exist. Skip connection verification. Get ME ID... OK ME_ID = 0xF515A1CE, 0x1898F821, 0x5E6BA15E, 0x414D7251 Load DownloadAgent... OK Search DA... OK [11] Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [PRELOADER] Preloader alive. Skip initializing external RAM Get device info... OK UFS CID (FW VER): KM8V9001JM-B813 (0600) Advanced Bypass Security... OK Send preloader... OK Load DownloadAgent... OK Search DA... OK [14] Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : KM8V9001JM-B813 UFS_FWVER : 0600 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Checking USB status... USB_HIGH_SPEED Read partitions info from phone... error(STATUS_PARTITION_TBL_NOT_EXIST) Read Flash Info done! After it no brom no preloader mode..... |
05-06-2023, 04:31 | #10 (permalink) |
Junior Member Join Date: Apr 2017
Member: 2711525 Status: Offline Thanks Meter: 21 | Vivo Y76 5G PD2156F Firmware Flashing Dead Boot Recover Successfully Vivo Y76 5G V2124 Flash With Pandora Dead Boot Recover Selected model: Vivo PD2156F (Vivo Y76 5G) Operation: Flash (Format all + download) Software version: 5.0 If BROM was disabled and you want write preloader partition not compatible for this model, phone will bricked. Recovery possible only with ISP mode. Continue? YES Parse scatter file... OK Load Rom Images... OK Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to [BOX or PC] in PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM_V1632 (Android),usb2ser.sys,3.0.1504.0] Device found at COM19 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 0989 Get sec config... OK [00000005] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6833] Currently using Beta/Unsafe operations LibUSB installed Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Preloader exist. Skip connection verification. Get ME ID... OK ME_ID = 0x0217FE84, 0x3067155B, 0xAABF6CF5, 0x5B33E1EC Load DownloadAgent... OK Search DA... OK [11] Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [PRELOADER] Preloader alive. Skip initializing external RAM Get device info... OK UFS CID (FW VER): KM8V9001JM-B813 (0600) Advanced Bypass Security... OK Send preloader... OK Load DownloadAgent... OK Search DA... OK [14] Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : KM8V9001JM-B813 UFS_FWVER : 0600 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Get scatter info... OK Checking USB status... USB_HIGH_SPEED Read partitions info from phone... OK Checking A/B state... OK Read product info... [EXT4] ... OK Product Brand : vivo Product Manufacturer : vivo Product Model : V2124 Product Name : 2124_EEA Product Device : 2124 Product Board : k6833v1_64 Board Platform : MTK6833 Build ID : TP1A.220624.014 Build Date : Fri Dec 9 10:30:07 CST 2022 Display ID : Funtouch OS 13 Global Security Patch : 2022-12-01 Version SDK : 33 Version Release : 13 Version Codename : REL Firmware Version : 38.12.2 Userdata FS Type : F2FS Creating autoformat settings... OK Format "UFS_LU0" partition( 0x00000000..0x003FFFFF )... OK Format "UFS_LU1" partition( 0x00000000..0x003FFFFF )... OK Format "UFS_LU2" partition( 0x00000000..0x1DCAFFFFFF )... OK Get scatter info... OK Verify scatter file... OK Do NAND BMT remark... OK Setup download info... OK Get partition table catagory... OK [GPT] Read mirror partition table... OK Generate mirror partition table... OK Downloading mirror partition table... OK Read major partition table... OK Generate major partition table... OK Downloading major partition table... OK Download "preloader"... OK Download "recovery"... OK Download "vbmeta"... OK Download "vbmeta_system"... OK Download "vbmeta_vendor"... OK Download "factory"... OK Download "vbmeta_oem"... OK Download "vbmeta_vgc"... OK Download "storage"... OK Download "metadata"... OK Download "efuse"... OK Download "md1img"... OK Download "spmfw"... OK Download "pi_img"... OK Download "dpm_1"... OK Download "dpm_2"... OK Download "scp1"... OK Download "scp2"... OK Download "sspm_1"... OK Download "sspm_2"... OK Download "mcupm_1"... OK Download "mcupm_2"... OK Download "gz1"... OK Download "gz2"... OK Download "lk"... OK Download "lk2"... OK Download "boot"... OK Download "logo"... OK Download "dtbo"... OK Download "tee1"... OK Download "tee2"... OK Download "super"... OK Download "cache"... OK Download "userdata"... OK Flashing done! Original source https://geeks-board.com/threads/vivo...ssfully.10106/ |
