12-03-2022, 19:59 | #1 (permalink) |
Freak Poster Join Date: Apr 2011 Location: Mexico
Member: 1547027 Status: Offline Thanks Meter: 42 | Error : /mnt2 (Data) not mounted! BACKUP PASSCODE Initializing... OK Connecting to device... OK Mounting system... FAIL Initializing disks... OK Mounting xART... OK Mounting Baseband Data... OK Mounting Preboot... OK Mounting Hardware... OK Mounting Data... FAIL quickCommand failed! Error : /mnt2 (Data) not mounted! Failed to mount partitions! Try Fix Mount or select another RAMDISK! Failed to locate activation data! UNLOCKTOOL 2022.11.30.0 Elapsed time : 14 seconds |
12-06-2022, 07:53 | #2 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,276 | Initializing... OK Connecting to device... OK Mounting system... FAIL Initializing disks... OK Mounting Baseband Data... OK Mounting xART... OK Mounting Preboot... OK Mounting Hardware... OK Mounting Data... OK Error : /mnt2 (Data) not mounted! Failed to mount partitions! Try Fix Mount or select another RAMDISK! Failed to locate activation data! |
12-16-2022, 23:21 | #3 (permalink) |
Junior Member Join Date: Feb 2015
Member: 2346218 Status: Offline Sonork: djawalak Thanks Meter: 1 | iphone 7 gsm BACKUP PASSCODE Initializing... OK Connecting to device... OK Mounting system... FAIL Initializing disks... OK Mounting Baseband Data... OK Mounting xART... OK Mounting Preboot... OK Mounting Hardware... OK Mounting Data... FAIL quickCommand failed! Error : /mnt2 (Data) not mounted! Failed to mount partitions! Try Fix Mount or select another RAMDISK! Failed to locate activation data! Operation stopped by user! UNLOCKTOOL 2022.12.13.0 Elapsed time : 3 minutes 49 seconds |
12-17-2022, 06:39 | #4 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: india
Member: 618404 Status: Offline Thanks Meter: 311 | Quote:
12-21-2022, 11:42 | #6 (permalink) |
No Life Poster Join Date: Sep 2004 Location: South Mrorocco Age: 49
Member: 80599 Status: Offline Sonork: 1621236 Thanks Meter: 279 | iphone 7plus gsm unable to activate RESTORE BACKUP Initializing... OK Connecting to device... OK Mounting system... FAIL Initializing disks... OK Mounting xART... OK Mounting Baseband Data... OK Mounting Hardware... OK Mounting Preboot... OK Mounting Data... OK Backup found : 0x0009503204b8403a.zip Initializing... OK Restoring data.. OK UNLOCKTOOL 2022.12.21.0 Elapsed time : 36 seconds |
02-22-2023, 21:48 | #10 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,772 | Quote:
b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
02-23-2023, 22:31 | #12 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,772 | i can guarantee that it works, i just did some iPhone7 two days ago. one was on ios 15.3.1, another was ios 14.3 (info from diagnostic mode) - both updated to ios 15.7.3, PWN with gaster via UnlockTool, ramdisk boot (File Gaster Ramdisk 15.x 5SE-6S-6SP-7G-7P) ramdisk booted normally, backup done normally, restore and block ota/reset too. b.r. Alex
02-24-2023, 13:27 | #13 (permalink) | |
Freak Poster Join Date: Feb 2005 Location: turkmenistan Age: 46
Member: 119517 Status: Offline Thanks Meter: 119 | Quote:
ios 15.7.3 mounting data fail | |
02-25-2023, 23:32 | #14 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,772 | restore again with 3u (retain data), re-check drivers, disable test mode, try on another pc. b.r. Alex
The Following User Says Thank You to Brka For This Useful Post: |
