12-14-2022, 13:06 | #1 (permalink) |
Junior Member Join Date: Dec 2022 Location: PAKISTAN
Member: 3027478 Status: Offline Thanks Meter: 0 | iPad Air 2 WIFI (A1566) iPadOS 15.7.1 Bypass FAIL Step 1. change SN Done Step 2. Get Activation Data Done. Step 3. PWND DFU Done Step 4. BOOT RAMDISK Done Step 5. BYPASS HELLO Failed with following Log Any one plz help me out |
12-14-2022, 13:18 | #2 (permalink) | |
Member: 3027478 Status: Offline Thanks Meter: 0 | Quote:
I get above ERROR.. and bypass on IPAD is not done | |
12-14-2022, 15:00 | #5 (permalink) |
Member: 3027478 Status: Offline Thanks Meter: 0 | Thank you guys for reply.. FIX MOUNT [2] Initializing... OK Connecting to device... OK Initializing disks... FAIL Failed to get disks list! UNLOCKTOOL 2022.12.13.0 Elapsed time : 1 second FIX MOUNT Initializing... OK Connecting to device... OK If tool got hang on fixing mount, just disconnect cable then reconnect cable then try Fix Mount again! Fixing mount... FAIL Failed to get disks list! UNLOCKTOOL 2022.12.13.0 Elapsed time : 6 seconds |
12-14-2022, 19:20 | #7 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,787 | After changing SN is mandatory to FULLY RESTORE the device. (itunes, from recovery/DFU or 3uTools second option in flash) Also, for SN bypass is mandatory to use Win10 with UT. p.s. In some cases, repairing drivers from 3uTools and disabling drivers signature in Win, can solve such issues. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following 3 Users Say Thank You to Brka For This Useful Post: |
