Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > UnlockTool
Old 11-15-2022, 09:38   #1 (permalink)
Member: 2612403
Sonork: 100.1575170
Thanks Meter: 93
iPad 6 Big problem loading Ramdisk
Anybody please
do you have any working solution for this idiotic device which I am fighting with for hours and unable to load ramdisk?
As soon as UT starts sending those files ibss the iPad powers up like a ****ing device?:
BOOT RAMDISK Checking for device... OK
Info : iPad (6th gen, Cellular) [iPad7,6-j72bap]
Boot : [IBOOT-2696.0.0.1.33] [DFU]
Pwnder : CHECKM8
Initializing... OK
Sending ssh... OK
Sending ibss.img4... OK
Sending ibec.img4... FAIL
ERROR: Unable to connect to device
Tips : If device keeps booting up while sending ibss or ibec
Press and Hold VOLUME DOWN + POWER while sending ibss and ibec
After done sending ibss and ibec you can release those buttons.
I tried holding power and Volume down button still the same.
Tried also holding forever since the begining of the PWNDFU putting stage but the same always.
Thanks
Old 11-15-2022, 14:35   #2 (permalink)
Member: 1026122
Sonork: 100.1640842
Thanks Meter: 160
Check the driver
Tx
Old 11-15-2022, 22:21   #3 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,454
Originally Posted by byteforce2016 View Post
Anybody please
Pwnder : CHECKM8
Initializing... OK
Sending ssh... OK
Thanks
check attached picture. if you have anything different than that,
then you need to fix drivers.
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
Old 11-16-2022, 05:02   #4 (permalink)
Member: 2612403
Sonork: 100.1575170
Thanks Meter: 93
Thanks all for getting involved to help but it is not driver issue at all
So I fixed by writing this beta IOS 15.6 firmware
https://updates.cdn-apple.com/2022Su...9_Restore.ipsw
(as long as Apple still signs it) and then holding just volume down during the last part of pwndfu process with EFT (keep in mind that UT PWNDFU is still broken for me - doesn't work at all) and until the end of load Ramdisk process
Old 11-16-2022, 05:02   #5 (permalink)
Member: 2612403
Sonork: 100.1575170
Thanks Meter: 93
Old 11-16-2022, 14:14   #6 (permalink)
Member: 353723
Thanks Meter: 3
I fixed driver and changed pwndfu but not work
i will try to downgrade to 15.7rc
Old 11-16-2022, 23:34   #7 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,454
iPad6 is very sensitive about PWNer,
In my case, it works only when PWNed on MAC,
with every pwner it boots ramdisk, but not final step.
With good PWN it goes fully and works.
thats just another hint about ramdisk.
b.r.
Alex
__________________
Old 11-18-2022, 20:39   #8 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,454
just did some testing with iPad6 ... here are the results :
(as I wrote before, not every PWNer will boot ramdisk till the end)
ios 15.7:
- ramdisk (generics1) boots normal
- backup normal, erase / restore normal, device starts normal
ios16.1.1:
- ramdisk ios 16.x.x Does not work. Always error.
- ramdisk Generics1 boot normal, backup normal (did not make restore backup)
- device after process in bootloop
- reflashing with 3uTools puts it back to life, with userdata retained (it was previously on same ios 16.1.1)
pictures attached.
b.r.
Alex
__________________
Old 11-21-2022, 10:56   #9 (permalink)
Member: 353723
Thanks Meter: 3
same error with ipad 5th wifi
need help
Old 11-21-2022, 11:40   #10 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,454
Clean windows, correct drivers and everything will work.
B.r
Alex
__________________
Old 11-21-2022, 11:43   #11 (permalink)
skyulock's Avatar
Member: 757064
Thanks Meter: 345
samething
Info : iPad Air 2 (Cellular) [iPad5,4-j82ap]
Boot : [IBOOT-1991.0.0.2.16] [DFU]
Pwnder : GASTER
Initializing... OK
Sending ssh... OK
Sending ibss.img4... FAIL
No response from device!
Old 11-21-2022, 11:43   #12 (permalink)
skyulock's Avatar
Member: 757064
Thanks Meter: 345
samething
Pwnder : GASTER
Initializing... OK
Sending ssh... OK
Old 11-21-2022, 21:18   #13 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,454
need help
Originally Posted by skyulock View Post
samething
Pwnder : GASTER
Initializing... OK
Sending ssh... OK
i've done both these devices, without any problem.
use correct drivers, PWN on mac, clean pc, and will work.
b.r.
Alex
__________________
The Following User Says Thank You to Brka For This Useful Post:
Old 11-22-2022, 10:26   #14 (permalink)
Member: 353723
Thanks Meter: 3
b.r.
Alex
can you make a tuto for us how to work
Old 11-23-2022, 17:04   #15 (permalink)
Member: 353723
Thanks Meter: 3
no one to help ???
please help
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.19680 seconds with 8 queries
