11-24-2022, 13:31 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: In the dark side ;) Age: 44
Member: 21508 Status: Offline Thanks Meter: 186 | Ipad IOS 16.1.1 Passcode is not support!!! Code: BACKUP PASSCODE Initializing... OK Connecting to device... OK Mounting system... OK Saved to : 0x000d38d21868ac26.zip activation_record does not exists!!! Passcode is not support!!! IC-Info.sisv does not exists!!! UNLOCKTOOL 2022.11.24.0 Elapsed time : 10 second |
11-24-2022, 20:32 | #2 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,778 | Quote:
what ipad model is in question ? b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
11-26-2022, 00:32 | #4 (permalink) | |
but ... Generics ramdisk, booted the device on ios16.1.1 and succesfully made backup. Cant restore on that version, but at least, backup is here, can be used after downgrade, and later, after bypass done, upgrading back to ios16.x with retain data. p.s. The problem on your device may also be bad PWN. try PWN that ipad on MAC, retry after. b.r. Alex
11-26-2022, 04:49 | #5 (permalink) |
Member: 21508 Status: Offline Thanks Meter: 186 | Yes I noticed that Generic Ramdisk can boot the device but I had bootloop after restoring password backup on ios16. To which version did you downgrade ? P.s. I have already tried all PWNDFU using MAC Thank you! |
