06-24-2022, 08:05 | #1 (permalink) |
Freak Poster Join Date: Nov 2017 Location: localhost
Member: 2781773 Status: Offline Thanks Meter: 140 | Iphone 7 IC-Info.sisv does not exists Connecting to device... OK Device GUID : B6A33D87-7183-4350-9124-5CA74818961C Saved to : C:\UnlockTool\Backups\LOCKDOWN\0x000a28ee0ef80026. ld activation_record does not exists!!! Passcode is not support!!! IC-Info.sisv does not exists!!! UNLOCKTOOL 2022.06.24.0 Elapsed time : 13 seconds |
The Following 2 Users Say Thank You to UM4 For This Useful Post: |
06-25-2022, 16:06 | #2 (permalink) |
No Life Poster Join Date: Feb 2004 Location: DZ W09 Age: 43
Member: 53408 Status: Offline Sonork: 100.1593951 Thanks Meter: 1,261 | BACKUP PASSCODE Initializing... OK Connecting to device... OK Device GUID : CF6AA6F7-6A6E-45FB-9F19-CB94A119F71F Saved to : C:\UnlockTool\Backups\LOCKDOWN\0x00127522006b002e. ld IC-Info.sisv does not exists!!! UNLOCKTOOL 2022.06.24.1 Elapsed time : 20 seconds |
The Following User Says Thank You to llcoolr For This Useful Post: |
07-01-2022, 14:45 | #3 (permalink) |
Freak Poster Join Date: Sep 2003 Location: Hungary Age: 46
Member: 40263 Status: Offline Thanks Meter: 14 | BACKUP PASSCODE Initializing... OK Connecting to device... OK Saved to : 0x000007b72a30bbc8.zip activation_record does not exists!!! Passcode is not support!!! IC-Info.sisv does not exists!!! UNLOCKTOOL 2022.06.29.0 Elapsed time : 8 seconds iphone 6s |
07-02-2022, 18:08 | #4 (permalink) |
No Life Poster Join Date: Dec 2013 Location: algeria
Member: 2081857 Status: Offline Sonork: 1000.2 Thanks Meter: 38 | sos iphone 7 hope iphone 7 BACKUP PASSCODE Initializing... OK Connecting to device... OK Saved to : 0x000e14560809803a.zip IC-Info.sisv does not exists!!! UNLOCKTOOL 2022.06.29.0 Elapsed time : 1 minute 8 seconds how to ceate ic-info.sisv this file is important or i should continue the process emergency |
07-03-2022, 08:59 | #5 (permalink) |
Freak Poster Join Date: Nov 2015 Location: Paris Age: 28
Member: 2483507 Status: Offline Thanks Meter: 81 | iPhone 6s same problem. BACKUP PASSCODE Initializing... OK Connecting to device... OK Device GUID : Saved to : C:\UnlockTool\Backups\LOCKDOWN\0x00026. ld activation_record does not exists!!! Passcode is not support!!! IC-Info.sisv does not exists!!! |
07-06-2022, 10:36 | #7 (permalink) |
Freak Poster Join Date: Jan 2017
Member: 2669864 Status: Offline Sonork: [email protected] Thanks Meter: 42 | If backup is successful just erase device and restore backup file, I have done that and it work |
07-09-2022, 21:15 | #11 (permalink) | |
Freak Poster Join Date: Oct 2016 Location: United Republic of Tanzania
Member: 2639338 Status: Offline Thanks Meter: 133 | Quote:
07-14-2022, 08:38 | #13 (permalink) |
No Life Poster Join Date: Jan 2004 Location: india
Member: 50772 Status: Offline Sonork: 100.1590990 Thanks Meter: 318 | iphone 6s Checking for device... OK Info : iPhone 6s [iPhone8,1-n71map] Boot : [IBOOT-2234.0.0.2.22] [DFU] Pwnder : CHECKM8 Connecting to server... OK Retrieving data... FAIL UNLOCKTOOL 2022.07.14.0 Elapsed time : 17 seconds |
02-21-2023, 02:43 | #14 (permalink) |
Junior Member Join Date: Feb 2023 Location: Philly USA
Member: 3031914 Status: Offline Thanks Meter: 0 | same issue active missing icsisv missing passcode and I still see no admin responded anyone have any idea how to fix. I even tried 3u flash and started over and that's when I added the activation missing smh the folders are empty activation records and fair play all empty anyone have anything. iPhone 7plus |
02-21-2023, 05:47 | #15 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Nadi
Member: 210669 Status: Offline Thanks Meter: 97 | if the phone is on hello screen than you than you will not be able to get signal only bypass. buy if the phone is password/disabled than you will be able to get it unlocked with signal |
The Following User Says Thank You to kava For This Useful Post: |
