iphone 7 Plus ios 15 Passcode Disabled / icloud bypass With Signal success Unlocktool 1. BOOT RAMDISK [2] Checking for device... OK Info : iPhone 7 Plus (GSM) [iPhone9,4-d111ap] Boot : [IBOOT-2696.0.0.1.33] [DFU] Pwnder : CHECKM8 Connecting to server... OK Initializing... OK Sending ssh... OK Sending ibss.img4... OK Sending ibec.img4... OK Executing loader... OK Sending devicetree.img4... OK Sending ramdisk.img4... OK Sending kernel.img4... OK Booting RAMDISK... OK UNLOCKTOOL 2022.09.24.0 Elapsed time : 55 seconds 2. BACKUP PASSCODE Initializing... OK Connecting to device... OK Mounting system... OK Saved to : 0x001d69e2246xxxxx.zip UNLOCKTOOL 2022.09.24.0 Elapsed time : 18 seconds 3. FACTORY RESET Initializing... OK Connecting to device... OK Mounting system... OK Erasing all... OK UNLOCKTOOL 2022.09.24.0 Elapsed time : 36 seconds 4. RESTORE BACKUP Initializing... OK Connecting to device... OK Mounting system... OK Backup found : 0x001d69e2246xxxxx.zip Initializing... OK Restoring data.. OK UNLOCKTOOL 2022.09.24.0 Elapsed time : 46 seconds all done:) |
Did you backup first wuth 3utools or just worked on UNLOCKTOOL, because i have the same devices with same issues except ios 13.x …. |
for ios15 ... 3uTools, upgrade with RETAIN USERDATA option, ramdisk - backup passcode - erase - ramdisk - restore b.r. Alex |
i have 2 ip7 and stuck here after pwndfu and gaster ramdisk BACKUP PASSCODE Initializing OK Connecting to device OK Mounting system FAIL Initializing disks OK Mounting xART OK Mounting Baseband Data OK Mounting Hardware OK Mounting Preboot OK Mounting Data OK Saved to 0x0016388830ba4d26 zip activation record does not exists!!! Passcode is not support!!! IC Info sisv does not exists!!! |
They were bypassed before, and updated later to different ios. Only possible if you already have backup, or ... paid services, of course, for full bypass with signal. p.s. That's why is important, after bypass, to disable update+reset/erase... b.r. Alex |
I have iPhone 7 plus successfully boot ramdisk, when I click backup passcode it's getting stuck at mounting data |
I can't fix it |
i have iphone 7 passcode, actually im new here and new in industrial in cp im just asking what i need to do to remove the passcode of iphone 7 |
