Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2016
Member: 2608490 Status: Online Thanks Meter: 900 | ![]() BOOT RAMDISK [2] Checking for device... OK Info : iPhone 7 Plus (GSM) [iPhone9,4-d111ap] Boot : [IBOOT-2696.0.0.1.33] [DFU] Pwnder : CHECKM8 Connecting to server... OK Initializing... OK Sending ssh... OK Sending ibss.img4... OK Sending ibec.img4... OK Executing loader... OK Sending devicetree.img4... OK Sending ramdisk.img4... OK Sending kernel.img4... OK Booting RAMDISK... OK UNLOCKTOOL 2022.09.24.0 Elapsed time : 55 seconds 2. BACKUP PASSCODE Initializing... OK Connecting to device... OK Mounting system... OK Saved to : 0x001d69e2246xxxxx.zip UNLOCKTOOL 2022.09.24.0 Elapsed time : 18 seconds 3. FACTORY RESET Initializing... OK Connecting to device... OK Mounting system... OK Erasing all... OK UNLOCKTOOL 2022.09.24.0 Elapsed time : 36 seconds 4. RESTORE BACKUP Initializing... OK Connecting to device... OK Mounting system... OK Backup found : 0x001d69e2246xxxxx.zip Initializing... OK Restoring data.. OK UNLOCKTOOL 2022.09.24.0 Elapsed time : 46 seconds all done ![]() |
The Following 3 Users Say Thank You to GSM AR For This Useful Post: |
![]() | #2 (permalink) |
Junior Member Join Date: Sep 2022 Location: Zoui ouled rechache, khenchela Age: 30
Member: 3021586 Status: Offline Sonork: Moh6zoui Thanks Meter: 0 | ![]() Did you backup first wuth 3utools or just worked on UNLOCKTOOL, because i have the same devices with same issues except ios 13.x …. |
![]() | #3 (permalink) | |
Moderator ![]() Join Date: Jun 1999 Location: Serbia Age: 47
Member: 163 Status: Offline Thanks Meter: 7,518 | Quote:
for ios15 ... 3uTools, upgrade with RETAIN USERDATA option, ramdisk - backup passcode - erase - ramdisk - restore b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
![]() | #4 (permalink) |
Junior Member Join Date: Nov 2022 Location: SA
Member: 3025139 Status: Offline Thanks Meter: 0 | i have 2 ip7 and stuck here after pwndfu and gaster ramdisk BACKUP PASSCODE Initializing OK Connecting to device OK Mounting system FAIL Initializing disks OK Mounting xART OK Mounting Baseband Data OK Mounting Hardware OK Mounting Preboot OK Mounting Data OK Saved to 0x0016388830ba4d26 zip activation record does not exists!!! Passcode is not support!!! IC Info sisv does not exists!!! |
![]() | #5 (permalink) |
![]() | #6 (permalink) | |
They were bypassed before, and updated later to different ios. Only possible if you already have backup, or ... paid services, of course, for full bypass with signal. p.s. That's why is important, after bypass, to disable update+reset/erase... b.r. Alex
The Following User Says Thank You to Brka For This Useful Post: |
