Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > UnlockTool
Old 11-18-2023, 04:32   #1 (permalink)
Member: 2948043
Thanks Meter: 2
need help, m0315f..
hi
after this dump (here : https://forum.gsmhosting.com/vbb/f11...ktool-3013334/ ) the phone it's working
but stay in the second samsung logo.. Two minutes then restart again
any help?
firstly this phone it was dead after many operation to repair network
i have backup ( nv..efs..) by cm2.
Old 11-18-2023, 05:03   #2 (permalink)
Member: 2948043
Thanks Meter: 2
any help?
any help?
Old 11-18-2023, 13:34   #3 (permalink)
Member: 172567
Thanks Meter: 78
Try to put it in recovery. If it's a dm-verity problem it will tell you that it failed. Does it has the original imei on it? In my case I shoud try with the dm verity patch and unlocking bootloader. If you can get the same version of firmware of the dump file, I shoud try to flash with it (the read out of the dump can have a failure (You can flash as mtk, just select the AP as Scatter/dump file).
The Following User Says Thank You to cartuchobahia For This Useful Post:
Old 11-18-2023, 23:21   #4 (permalink)
Member: 2948043
Thanks Meter: 2
thank you, but i have not understand exactly..
about recovery mode, yes anything it's ok recovery and download mode, i writed this firmware (m013fddu6avc5) from z3x, done, but the same problem.
and i tried unlock and relock bootloader, done, and no thing.
if i can to erase all firmware and write it again or no??
or what i do one by one?
Old 11-19-2023, 02:24   #5 (permalink)
Member: 172567
Thanks Meter: 78
use the dm-verity option. And if you can fullflash phone but with normal flash, not dump
Old 11-19-2023, 02:47   #6 (permalink)
Member: 2948043
Thanks Meter: 2
thank you..
look at this picture..
I don't have u6 firmware, except z3x firmware. I tried it in download mode, done but the same problem..
I will try again with it
now the phone on samsung logo only.. not restart
Old 11-19-2023, 03:43   #7 (permalink)
Member: 2948043
Thanks Meter: 2
thank you. good result
it's working now. i used this firmware (M013FDDU6AVC5_ODM6AVA2) on download mode..
now : unknown baseband.
Old 11-19-2023, 04:06   #8 (permalink)
Member: 2948043
Thanks Meter: 2
now the best result
baseband and imei are correct.......
option: restore backup
DA: USB: HIGH-SPEED
Boot done [1]
Reading...
Ok
Search for MT6739__D079707578E818202AD9D3BD46D7F8AC
Backup for connected device Found
Restore it?
Backup selected: C:\InfinityBox\CM2MT2\backup\MT6739__D079707578E81 8202AD9D3BD46D7F8AC.7z
Restore...
Restore: nvcfg
ExtSparse: Compression ratio: 100%
Restore: nvdata
ExtSparse: Compression ratio: 87%
Restore: nvram
Restore: persist
Skip: preloader
Strange Image. Skip: proinfo
Restore: protect1
ExtSparse: Compression ratio: 85%
Reconnect Power/Cable now
Done: 00:01:01
الحمد لله والله الموفق
Old 11-20-2023, 00:00   #9 (permalink)
Member: 172567
Thanks Meter: 78
Good to know. Allways make backup of efs, it solves some problem with the phone and eventually can solve a problem with phones that allready come with a problem (it's good to indicate on the backup file the binary of the readout for future use)
Old 11-20-2023, 01:53   #10 (permalink)
Member: 2948043
Thanks Meter: 2
yes exactly, thanks.
Page generated in 0.17320 seconds with 8 queries
