Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > UnlockTool
Old 04-10-2021, 05:01   #1 (permalink)
Member: 2974628
Sonork: 11223344
Thanks Meter: 178
★★★ Post All Successfully Story Repaired Phones by UnlockTool ★★★
by UnlockTool
________________________
Vivo V7 Remove Passcode By Unlock tool
-Open Unlock tool
-Select Vivo tab
-Search Exact model
-Disassembly Unit for Testpoint
-Open Device Manager and find the Qualcomm Port of your phone
-If device already read Select Factory Reset in Unlock tool then wait until process is success
black baby boy names 2015
The Following 7 Users Say Thank You to TeamBobParts For This Useful Post:
Old 04-10-2021, 05:03   #2 (permalink)
Member: 2974628
Sonork: 11223344
Thanks Meter: 178
Vivo Y91 - Passcode remove only ( No data loss by Unlock tool )
Procedure:
-Open Unlock Tool
-Select Vivo Tab
-Search Exact model
-Select Safe Format
-Power off the phone and insert cable into your Desktop/Laptop ( Take note: No need boot key just simply off your phone then insert cable)
-Wait until process is done.
Screenshots:
The Following 3 Users Say Thank You to TeamBobParts For This Useful Post:
Old 04-10-2021, 05:05   #3 (permalink)
Member: 2974628
Sonork: 11223344
Thanks Meter: 178
Xiaomi Redmi 7a MI Account Bypass Done via Unlocktool
https://drive.google.com/file/d/1V5M...lP7NsFOVd/view
The Following 8 Users Say Thank You to TeamBobParts For This Useful Post:
Old 04-10-2021, 08:25   #4 (permalink)
Member: 2974628
Sonork: 11223344
Thanks Meter: 178
HOW TO FAKE IOS 14 4 1 USING UNLOCK TOOL GPP UNLOCK JAILBREAK
https://www.youtube.com/watch?v=dJ6RA9H5Iyo
The Following 2 Users Say Thank You to TeamBobParts For This Useful Post:
Old 04-10-2021, 08:27   #5 (permalink)
Member: 2974628
Sonork: 11223344
Thanks Meter: 178
OPPO F9 PASSWORD REMOVE ONE CLICK META MODE NO NEED TESTPOINT
OPPO F9 Password Problem
Solution
Without baklasan
Buy Unlock Tool Activation
Open Unlock tool then log in your account
go to oppo tab
the find exact model
do to META MODE tab
click Factory Reset EMMC
Hold Volume UP AND DOWN CONNECT USB
https://www.youtube.com/watch?v=hUmzsYTuUC8
The Following 4 Users Say Thank You to TeamBobParts For This Useful Post:
Old 04-10-2021, 08:29   #6 (permalink)
Member: 2974628
Sonork: 11223344
Thanks Meter: 178
Oppo A83 CPH1729 Password Lock Done by Unlocktool No Need Tespoint
Open Unlock Tool.
Hold Volume Up and Down. Then Conect phone to pc.
buy marimo balls
Old 04-12-2021, 06:45   #7 (permalink)
Member: 2974628
Sonork: 11223344
Thanks Meter: 178
realme c2 password removed using unlock tool
run unlocktool
click oppo - select realme c2 (auth bypass) (brom factory)
select meta mode
click boot meta - phone in off mode, hold vol+ vol- then connect usb cable to pc (just wait till phone detected in meta mode)
click factory reset (3) (ufs)
when you see shutting down device...ok , disconnect device from pc and do the hard reset - wipe data
Old 04-12-2021, 12:00   #8 (permalink)
Tien Dung GSM's Avatar
Member: 2643704
Sonork: Zalo:0932606079
Thanks Meter: 135
Selected Model : Vivo Y20-Y20i-Y20s
Code Name : PD2034F-V2027-V2029
Operation : Factory Reset [5]
Authenticating... OK
Retrieving data... OK [270,16 KiB]
Initializing data... OK
Searching for HS-USB QDLoader 9008... COM33
Connection : USB 2.0 High-Speed
USB Driver : [Qualcomm Incorporated] qcusbser - Version : 2.1.2.0
Connecting to device... OK
Handshaking... OK
Reading bootloader info... OK
Serial : 1881420049 SoC : [Snapdragon 460] [SM4250-AA] [0x001360E1]
OEM : Vivo [0x0073] Model : Unknown [0x0000]
PK_HASH[0] :A7DF36FFD7AB557C67A6C26675E2795C
PK_HASH[1] :922CF671308CFD7169BEDB84424C862B
Writing flash programmer... OK
Connecting to flash programmer... OK
Configuring device... OK
Setting boot LUN1... OK
Firehose config : UFS [Sector:4096] [Target:0] [Host:1048576]
Erasing FRP... OK
Erasing USERDATA... OK
Rebooting... OK
UNLOCKTOOL
The Following User Says Thank You to Tien Dung GSM For This Useful Post:
Old 04-13-2021, 04:42   #9 (permalink)
Member: 2974628
Sonork: 11223344
Thanks Meter: 178
Huawei Y9 2019 jkm-lx2 frp done using Unlocktool
restaurants on sawmill rd
Procedure
Find testpoint
Open Unlocktool
Need Driver c
Off Disable Driver Signature
Click Kirin 710 Frp 1.0
Do TP method -Insert USB cable
Old 04-14-2021, 15:38   #10 (permalink)
GsmLiberty's Avatar
Member: 82759
Thanks Meter: 153
Welcome UnlockTool Team in the best GSM forum in the world
I recommend this tool
SM-A750FN/DS & SM-N960F/DS - DONE
The Following 4 Users Say Thank You to GsmLiberty For This Useful Post:
Old 04-15-2021, 09:19   #11 (permalink)
ChuyenMobileGsm's Avatar
Member: 2984558
Thanks Meter: 634
Oppo F11 Pro CPH1969 Extract OFP + FLASH File By UnlockTool
http://www.youtube.com/watch?v=be1b7fDWo6E
The Following 2 Users Say Thank You to ChuyenMobileGsm For This Useful Post:
Old 04-15-2021, 09:20   #12 (permalink)
Member: 2984558
Thanks Meter: 634
Huawei Y6p MED-LX9 | MED-LX9N MTK Remove Account ID Successfully By UnlockTool.
http://www.youtube.com/watch?v=o-rjl_Cq5gY
The Following 6 Users Say Thank You to ChuyenMobileGsm For This Useful Post:
Old 04-17-2021, 07:30   #13 (permalink)
Member: 2643704
Thanks Meter: 135
Oppo F9 Screen Lock Remove By Unlocktool
Waiting for device... COM6
USB Driver : [MediaTek Inc.] wdm_usb - Version : 3.0.1504.0
Boot Mode : PRELOADER [22D9:0006]
Handshaking... OK
Booting META mode... OK
Phone must have battery inside!
Waiting for device... COM13
Boot Mode : META [0E8D:2007]
Initializing META... OK
Connecting to META... OK [Ver:0] [Rate:921600]
Reading Software Info... OK
Brand : OPPO
Board : oppo6771
Platform : mt6771
Model : CPH1825
Android : 10
Security Patch : 2020-12-05
Build ID : CPH1825EX_11_F.16
Build Date : Fri Dec 18 06:02:49 CST 2020
Oppo Name : OPPO F9
Oppo Model : CPH1825
Rebooting device... OK
Old 04-21-2021, 18:29   #14 (permalink)
Member: 572216
Sonork: 100.1612300
Thanks Meter: 3,737
Xiaomi Redmi 9C Erase FRP Done
[COLOR=#444444;][BROM] ERASE FRP[/COLOR]
 Selected Model : Xiaomi Redmi 9C
Code Name : Angelican
Operation : Erase FRP [1]
  Retrieving data... OK [2.38 MiB]
Initializing config... OK
Waiting for device... COM43
  Connection : USB 1.0 High-Speed
  USB Driver : [Sony Mobile Communications] usbser - Version : 2.0.0.6
  Boot Mode : BOOTROM [0E8D:0003]
Disabling Watchdog... OK
Bypassing authentication... OK
Connecting to BROM... OK
Sending DA... OK [211.62 KiB]
Syncing with DA... OK
  HW Chip : MT6765 [6765] - HW Ver : 0xCA00 - SW Ver : 0x0000
  Bootloader Ver : 0x00 - Secure Ver : 0x00
  Internal RAM Size : 448 KiB
  External RAM Size : 3 GiB
  Storage : EMMC - CID : 43000115.3444544A.D4020452.D38746BE
  Boot1 : 4 MiB - Boot2 : 4 MiB - RPMB : 4 MiB - User Area  : 58.24 GiB
Reading partition info... OK [43]
Formatting FRP... OK
UNLOCKTOOL
Old 04-22-2021, 17:23   #15 (permalink)
Member: 572216
Sonork: 100.1612300
Thanks Meter: 3,737
vivo 1906 y11 FACTORY RESET Done
[COLOR=#444444;][EDL] FACTORY RESET [/COLOR]
 Selected Model : Vivo Y11 (1906)
Code Name : PD1930F/PD1930CF
Operation : Factory Reset [2]
  Retrieving data... OK [218.7 KiB]
Searching for HS-USB QDLoader 9008... COM97
  USB Driver : [HS Corporation] ghsser - Version : 10.2104.1.2
Handshaking... OK
  Serial : 1180475104 SoC : [Snapdragon 439] [SDM439] [0x000BF0E1]
  OEM : Qualcomm [0x0000] Model : Unknown [0x0000]
  PK_HASH[0] :60BA997FEF6DA9F05885FA11F1DD6D2A
  PK_HASH[1] :90D052A257A09C2075D7246CC73C0D43
Firehose config : eMMC [Sector:512] [Target:4096] [Host:1048576]
Reading partition map... OK
LU Count : 1
Reading info... OK
   Model Name : vivo 1906
   Product Name : PD1930F_EX
   Manufacturer : vivo
   Android Version : 9
   Security Patch : 2021-02-01
   Display ID : PKQ1.190616.001 release-keys
Formatting data... OK
Erasing FRP... OK
Total sector : 64
Rebooting to FASTBOOT... OK
UNLOCKTOOL v2021.04.21.0
Elapsed time : 22 seconds
Page generated in 0.13832 seconds with 9 queries
