★★★ Post All Successfully Story Repaired Phones by UnlockTool ★★★ Post All Successfully Story Repaired Phones by UnlockTool https://i.ibb.co/Cn3NF6V/Unlock-Tool-Telegram.png https://i.ibb.co/Dk3VXLq/line-separator-1.jpg https://i.ibb.co/HXF35Ss/Fllow1.pnghttps://i.ibb.co/vh8YZX0/Folllow3.pnghttps://i.ibb.co/tP1cBZw/Follow2.pnghttps://i.ibb.co/SJq1k7j/Follow4.png ________________________ Vivo V7 Remove Passcode By Unlock tool -Open Unlock tool -Select Vivo tab -Search Exact model -Disassembly Unit for Testpoint -Open Device Manager and find the Qualcomm Port of your phone -If device already read Select Factory Reset in Unlock tool then wait until process is success https://i.postimg.cc/wjQN03PY/HLCr0xc.jpgblack baby boy names 2015 |
Vivo Y91 - Passcode remove only ( No data loss by Unlock tool ) Procedure: -Open Unlock Tool -Select Vivo Tab -Search Exact model -Select Safe Format -Power off the phone and insert cable into your Desktop/Laptop ( Take note: No need boot key just simply off your phone then insert cable) -Wait until process is done. Screenshots: https://i.postimg.cc/g2mXXm0S/mhfbhjn.jpg |
Xiaomi Redmi 7a MI Account Bypass Done via Unlocktool |
HOW TO FAKE IOS 14 4 1 USING UNLOCK TOOL GPP UNLOCK JAILBREAK https://www.youtube.com/watch?v=dJ6RA9H5Iyo |
OPPO F9 PASSWORD REMOVE ONE CLICK META MODE NO NEED TESTPOINT OPPO F9 Password Problem Solution Without baklasan Buy Unlock Tool Activation Open Unlock tool then log in your account go to oppo tab the find exact model do to META MODE tab click Factory Reset EMMC Hold Volume UP AND DOWN CONNECT USB https://www.youtube.com/watch?v=hUmzsYTuUC8 |
Oppo A83 CPH1729 Password Lock Done by Unlocktool No Need Tespoint Oppo A83 CPH1729 Password Lock Done by Unlocktool No Need Tespoint Open Unlock Tool. Hold Volume Up and Down. Then Conect phone to pc. https://i.postimg.cc/k4wz8LkP/IMG-20210331-115607.jpgbuy marimo balls |
realme c2 password removed using unlock tool run unlocktool click oppo - select realme c2 (auth bypass) (brom factory) select meta mode click boot meta - phone in off mode, hold vol+ vol- then connect usb cable to pc (just wait till phone detected in meta mode) click factory reset (3) (ufs) when you see shutting down device...ok , disconnect device from pc and do the hard reset - wipe data https://i.postimg.cc/L4L2g4Ys/FvMPH98.png |
Selected Model : Vivo Y20-Y20i-Y20s Code Name : PD2034F-V2027-V2029 Operation : Factory Reset [5] Authenticating... OK Retrieving data... OK [270,16 KiB] Initializing data... OK Searching for HS-USB QDLoader 9008... COM33 Connection : USB 2.0 High-Speed USB Driver : [Qualcomm Incorporated] qcusbser - Version : 2.1.2.0 Connecting to device... OK Handshaking... OK Reading bootloader info... OK Serial : 1881420049 SoC : [Snapdragon 460] [SM4250-AA] [0x001360E1] OEM : Vivo [0x0073] Model : Unknown [0x0000] PK_HASH[0] :A7DF36FFD7AB557C67A6C26675E2795C PK_HASH[1] :922CF671308CFD7169BEDB84424C862B Writing flash programmer... OK Connecting to flash programmer... OK Configuring device... OK Setting boot LUN1... OK Firehose config : UFS [Sector:4096] [Target:0] [Host:1048576] Erasing FRP... OK Erasing USERDATA... OK Rebooting... OK UNLOCKTOOL |
Huawei Y9 2019 jkm-lx2 frp done using Unlocktool https://i.postimg.cc/d3dWm0rJ/93KOMDt.jpgrestaurants on sawmill rd Procedure Find testpoint Open Unlocktool Need Driver c Off Disable Driver Signature Click Kirin 710 Frp 1.0 Do TP method -Insert USB cable https://i.postimg.cc/PrW3CPd4/4cDTm6m.jpg |
Welcome UnlockTool Team in the best GSM forum in the world I recommend this tool SM-A750FN/DS & SM-N960F/DS - DONE https://images90.fotosik.pl/492/cb8c72fe62b5a10cmed.jpg https://images92.fotosik.pl/492/3417910deab3f006med.jpg https://images90.fotosik.pl/492/6869f5544a626cfdmed.jpg |
Oppo F11 Pro CPH1969 Extract OFP + FLASH File By UnlockTool Oppo F11 Pro CPH1969 Extract OFP + FLASH File By UnlockTool |
Huawei Y6p MED-LX9 | MED-LX9N MTK Remove Account ID Successfully By UnlockTool. Huawei Y6p MED-LX9 | MED-LX9N MTK Remove Account ID Successfully By UnlockTool. |
Oppo F9 Screen Lock Remove By Unlocktool Waiting for device... COM6 Connection : USB 2.0 High-Speed USB Driver : [MediaTek Inc.] wdm_usb - Version : 3.0.1504.0 Boot Mode : PRELOADER [22D9:0006] Handshaking... OK Booting META mode... OK Phone must have battery inside! Waiting for device... COM13 Connection : USB 2.0 High-Speed USB Driver : [MediaTek Inc.] wdm_usb - Version : 3.0.1504.0 Boot Mode : META [0E8D:2007] Authenticating... OK Initializing META... OK Connecting to META... OK [Ver:0] [Rate:921600] Reading Software Info... OK Brand : OPPO Board : oppo6771 Platform : mt6771 Model : CPH1825 Android : 10 Security Patch : 2020-12-05 Build ID : CPH1825EX_11_F.16 Build Date : Fri Dec 18 06:02:49 CST 2020 Oppo Name : OPPO F9 Oppo Model : CPH1825 Erasing USERDATA... OK Rebooting device... OK |
Xiaomi Redmi 9C Erase FRP Done Code: [COLOR=#444444;][BROM] ERASE FRP[/COLOR] |
vivo 1906 y11 FACTORY RESET Done Code: [COLOR=#444444;][EDL] FACTORY RESET [/COLOR] |
