Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > UnlockTool
Old 03-12-2025, 11:52   #1216 (permalink)
NeeMan's Avatar
Member: 767786
Thanks Meter: 322
Nokia C10 FRP
[SPRD] FACTORY RESET Selected Platform : SC7731E_Bypass
Connect Testpoint or hold VOL DOWN! Instruction here!
Waiting for device... COM25 (SPRD U2S Diag)
USB : USB\VID_1782&PID_4D00\6&252A31E1&0&1
Initializing loader... OK
Protocol : SPRD3
Sending payload... OK
Sending auth data... OK
Sending preloader1... OK
Sending preloader2... OK
Booting loader, please wait... OK
Boot ver: Spreadtrum Boot Block version 1.1
Sending FDL1... OK
Sending FDL2... OK
Reading Serial Number... N.A
Reading partitions info... OK [74] [1024]
Dual boot-slot : A
Erasing FRP (persist)... OK
Erasing USERDATA... OK
UNLOCKTOOL 2025.03.10.0
Elapsed time : 34 seconds
Old 03-12-2025, 11:59   #1217 (permalink)
NeeMan's Avatar
Member: 767786
Thanks Meter: 322
Nokia C10 FRP
Protocol : SPRD3
Sending FDL1... OK
Sending FDL2... OK
Dual boot-slot : A
Old 03-12-2025, 21:30   #1218 (permalink)
Member: 111140
Thanks Meter: 75
Smile 😀✔️Samsung SM-N976V FRP DONE
😀😀✔️Samsung SM-N976V FRP DONE
[EDL] ERASE FRP Waiting for HS-USB QDLoader 9008... COM37
Selected Model : Samsung Note10+ 5G (BIT 8)
Code Name : SM-N976V (BIT8)
Operation : Erase FRP [1]
Authenticating... OK
Retrieving server data... OK [298.7 KiB]
Initializing data... OK
Connecting to device... OK
Writing flash programmer... OK
Connecting to flash programmer... OK
Configuring device... OK
Firehose config : UFS [Sector:4096] [Target:0] [Host:1048576]
Reading partition map... OK - LU Count : 4
Reading software info... OK [system]
Model Name : SM-N976V
Product Name : d2xqvzw
Manufacturer : samsung
Platform : msmnile
Android Version : 10
Security Patch : 2020-04-01
Build ID : QP1A.190711.020.N976VVRU3CTC9
Build : N976VVRU3CTC9
Build Date : Fri Mar 20 21:44:40 KST 2020
PDA : N976VVRU3CTC9
Erasing FRP... Read-Only
Switched to SMART Mode!
Erasing FRP... OK
Rebooting... OK
Elapsed time : 53 seconds
UnlockTool The best Toooooool
Regards,
GsmOrient.
Old 03-17-2025, 10:58   #1219 (permalink)
Member: 111140
Thanks Meter: 75
Smile 😀✔️😀✔️xiaomi 11T Hang on FastBoot after Flashing fixed
😀✔️😀✔️xiaomi 11T Hang on FastBoot after Flashing had fixed by [MI] FIX CORRUPTION
[MI] FIX CORRUPTION Initializing usb... OK
Waiting for device... COM29 [BOOTROM:0E8D:0003]
Bypassing authentication... OK
Analyzing... preloader_agate.bin [MT6891/MT6895:4:448] [Internal]
Vendor : XIAOMI
Reading hardware info... OK
Hardware : MT6893 [1100|1200|1300|8020|8050] 0950 8A00 CA00 0000
Security Config : SCB SLA DAA
MEID : 1C771E4819D31D256D924A103DF79A37
Sending Download-Agent [1]... OK
Syncing with device... OK
Booting device... OK
Syncing with DA... OK
Storage : UFS - FWVer : 0200 - CID : KLUDG4UHDC-B0E1
Vendor ID : Samsung [0x1CE]
UFS: LU0 Size : 4 MiB - LU1 Size : 4 MiB - LU2 Size : 119.17 GiB
Reading partition info... OK [77]
Reading device info... SKIP [EROFS]
Checking Find Device Status... SKIP (not found)
Fixing Corruption... OK
Tips : If the problem is still persist, you need to relock bootloader then fix again!
Elapsed time : 40 seconds
Unlock Tool Great Tool
Best Regards
GsmOrient
Old 03-17-2025, 23:23   #1220 (permalink)
Member: 2951556
Thanks Meter: 943
[EDL] FACTORY RESET Waiting for HS-USB QDLoader 9008... COM25
Selected Model : Vivo Y20 | Y20i | Y20s
Code Name : PD2034F | PD2034AM | V2029
Operation : Factory Reset [5]
**Authenticating... OK
**Retrieving server data... OK [270,22 KiB]
Handshaking... OK
Reading bootloader info... OK
**Serial : 3934862704 SoC : [Snapdragon 460] [SM4250-AA] [0x001360E1]
**OEM : Vivo [0x0073] Model : Unknown [0x0000]
**PK_HASH[0] : A7DF36FFD7AB557C67A6C26675E2795C
**PK_HASH[1] : 922CF671308CFD7169BEDB84424C862B
**Firehose config : UFS [Sector:4096] [Target:0] [Host:1048576]
Erasing FRP... OK
Rebooting... OK
Elapsed time : 24 seconds
Old 03-20-2025, 13:04   #1221 (permalink)
Member: 172261
Thanks Meter: 383
[EDL] ERASE FRP Waiting for HS-USB QDLoader 9008... COM36
Selected Model : Samsung A72 (BIT 6)
Code Name : SM-A725F | SM-A725F/DS (BIT6)
**Retrieving server data... OK [297.51 KiB]
Reading partition map... OK - LU Count : 6
Reading software info... OK [super]
** Model Name : SM-A725F
** Product Name : a72qnsxx
** Manufacturer : samsung
** Platform : atoll
** Android Version : 13
** Security Patch : 2023-09-01
** Build ID : TP1A.220624.014.A725FXXU6DWH2
** Build : A725FXXU6DWH2
** Build Date : Mon Aug 21 16:26:42 KST 2023
** Code Name : SM-A725F
** PDA : A725FXXU6DWH2
Erasing FRP... OK
Rebooting... OK
UNLOCKTOOL 2025.03.18.0
Elapsed time : 2 minutes 17 seconds
Old 03-20-2025, 17:29   #1222 (permalink)
Unlocker AL's Avatar
Member: 3617
Thanks Meter: 594
Viko View 2 frp unlock ok
Old 03-22-2025, 09:30   #1223 (permalink)
Member: 1114818
Thanks Meter: 253
Samsung S22 Ultra 5G FRP DONE
[COLOR=#444444;][EDL] ERASE FRP[/COLOR]
Waiting for HS-USB QDLoader 9008... COM23
Selected Model : Samsung S22 Ultra 5G (BIT 7)
Code Name : SM-S908U/S908U1 (BIT7)
Retrieving server data... OK [735,76 KiB]
Model Name : SM-S908U1_NA_XAA_QKEY0
Manufacturer : SAMSUNG
Build ID : S908U1UEU7EXK6
Erasing FRP... OK
Rebooting... OK
UNLOCKTOOL 2025.03.22.0
Elapsed time : 55 seconds
Old 03-22-2025, 10:48   #1224 (permalink)
adnanali's Avatar
Member: 207308
Thanks Meter: 472
ok frp
[PRELOADER] ERASE FRP Selected auth : CUSTOM DA
**Retrieving server data... OK [339.75 KiB]
Phone must have battery inside!
Waiting for device... COM8 [PRELOADER:0E8D:2000]
Handshaking... OK
* Hardware : MT6765 [Helio G25|G35|P35] 0766 8A00 CA00 0000
* Security Config : SCB SLA DAA
* MEID : FB73A5234B595F620782FE2D486C43C3
Custom DA(e) : Huawei_Honor_MT6765_DA
Sending Download-Agent... OK
Syncing with target... OK
Booting device (preloader auth)... OK
**Storage : EMMC - CID : 474E0113.31324D32.B4301032.11BDA0E
**Vendor : Micron - Name : G2M212 - Serial : 3658396720 - Rev : 16
**Boot1 : 4 MiB - Boot2 : 4 MiB - RPMB : 16 MiB - User Area : 116.48 GiB
Reading partition info... OK [93]
Reading device info... OK [super]
** Model Name : WDY-LX2
** Manufacturer : HUAWEI
** OEM Model : WDY-L32
** OEM Vendor : def/meafnaf
** EMUI Version : WDY-L32 8.0.0.178(C185E2R2P3)
Erasing FRP... OK
Elapsed time : 31 seconds
Old 03-24-2025, 13:28   #1225 (permalink)
Member: 3617
Thanks Meter: 594
Nubia Z2353 frp Removed ok
Old 03-24-2025, 19:14   #1226 (permalink)
gile@gile's Avatar
Member: 1473716
Thanks Meter: 1,293
Lenovo Tab M10 TB328FU Frp done
ERASE FRP Selected Platform : Tiger T610_64_Bypass
Waiting for device... COM4 (SPRD U2S Diag)
USB : USB\VID_1782&PID_4D00\5&C6BE489&0&1
Protocol : SPRD3
Sending FDL1... OK
Sending FDL2... OK
Reading partitions info... OK [85] [1024]
Dual boot-slot : B
** Model Name : TB328FU
** Manufacturer : Lenovo
** Platform : TB328FU
** Android Version : 12
** Security Patch : 2025-01-05
** Build ID : TB328FU_S200157_250208_ROW
** Build Date : Sat Feb 8 10:23:45 CST 2025
Erasing FRP... OK
Old 03-24-2025, 19:29   #1227 (permalink)
gile@gile's Avatar
Member: 1473716
Thanks Meter: 1,293
Protocol : SPRD3
Sending FDL1... OK
Sending FDL2... OK
Dual boot-slot : B
Erasing FRP... OK
Old 03-24-2025, 19:56   #1228 (permalink)
gile@gile's Avatar
Member: 1473716
Thanks Meter: 1,293
Protocol : SPRD3
Sending FDL1... OK
Sending FDL2... OK
Dual boot-slot : B
Erasing FRP... OK
Old 03-24-2025, 20:08   #1229 (permalink)
gile@gile's Avatar
Member: 1473716
Thanks Meter: 1,293
Protocol : SPRD3
Sending FDL1... OK
Sending FDL2... OK
Dual boot-slot : B
Erasing FRP... OK
I am asking the admin to delete my unnecessary posts
Old 03-25-2025, 01:05   #1230 (permalink)
Member: 2951556
Thanks Meter: 943
**Retrieving server data... OK [363,22 KiB]
Waiting for device... COM21 [PRELOADER:0E8D:2000]
Handshaking... OK
* Hardware : MT6768 [Helio G70|G80|G85|P65] 0707 8A00 CA00 0000
* Security Config : SCB DAA
* MEID : 0EC70F0027B4DD7246B87226A020EDD5
Custom DA(e) : Huawei_Honor_MT6768_DA
**Storage : EMMC - CID : 44000145.32313449.F4E21238.1FBB77EE
**Vendor : Scandisk - Name : DI4128 - Serial : 2012148962 - Rev : 18
**Boot1 : 4 MiB - Boot2 : 4 MiB - RPMB : 16 MiB - User Area : 116,48 GiB
Reading partition info... OK [105]
** Model Name : JDY-LX3P
** OEM Model : JDY-L43P
** OEM Vendor : def/la
** EMUI Version : JDY-L43P 8.0.0.212(C605E2R2P2)
Erasing FRP... OK
Elapsed time : 36 seconds
Page generated in 0.27675 seconds with 9 queries
