redmi note 10 fail hi i'm trying to remove mi from redmi note10 it stucks on reading info i repeated the operation 3 times but always same RESET MICLOUD Selected Model : Xiaomi Redmi Note 10 Code Name : mojito | sunny Operation : Reset MiCloud [2] Authenticating... OK Retrieving data... OK [293.87 KiB] Initializing data... OK Searching for HS-USB QDLoader 9008... COM20 Connection : USB 2.0 High-Speed Unofficial driver detected! Please install proper Qualcomm driver! USB Driver : [Network Connect] bmusbser - Version : 3.0.0.0 Connecting to device... OK Handshaking... OK Reading bootloader info... OK Serial : 4232335863 SoC : [Snapdragon 675] [SM6150] [0x000950E1] OEM : Xiaomi [0x0072] Model : Unknown [0x0000] PK_HASH[0] :1BEBE3863A6781DB4B01086063007334 PK_HASH[1] :DE9E5CA14971C7C4F4358EC9D79CDA46 Writing flash programmer... OK Connecting to flash programmer... OK Configuring device... Auth! Authenticating with server... OK Configuring device... OK Firehose config : UFS [Sector:4096] [Target:0] [Host:1048576] Reading partition map... OK - LU Count : 6 Reading info... please answer me and not delete this post thx |
RESET MICLOUD Selected Model : Xiaomi Redmi Note 10 Code Name : mojito | sunny Operation : Reset MiCloud [2] Authenticating... OK Retrieving data... OK [293.87 KiB] Initializing data... OK Searching for HS-USB QDLoader 9008... COM20 Connection : USB 2.0 High-Speed Unofficial driver detected! Please install proper Qualcomm driver! USB Driver : [Network Connect] bmusbser - Version : 3.0.0.0 Connecting to device... OK Handshaking... OK Reading bootloader info... OK Serial : 4232335863 SoC : [Snapdragon 675] [SM6150] [0x000950E1] OEM : Xiaomi [0x0072] Model : Unknown [0x0000] PK_HASH[0] :1BEBE3863A6781DB4B01086063007334 PK_HASH[1] :DE9E5CA14971C7C4F4358EC9D79CDA46 Writing flash programmer... OK Connecting to flash programmer... OK Configuring device... Auth! Authenticating with server... OK Configuring device... OK Firehose config : UFS [Sector:4096] [Target:0] [Host:1048576] Reading partition map... OK - LU Count : 6 Reading info... FAIL Failed to read metadata! Erasing lock data... FAIL Division by zero Disabling MiCloud... FAIL Failed to erase security! Tips : Try another usb cable! Erasing FRP... FAIL UNLOCKTOOL 2021.10.11.0 Elapsed time : 4 minutes 42 seconds |
Is there anyone from team here to support ?!! |
