Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > UnlockTool
Old 11-09-2022, 00:08   #1 (permalink)
wykie's Avatar
Member: 36126
Thanks Meter: 310
samaung A32 5G not resetting
Hi,
I am trying to reset samsung A32 5G
It has Blocked remotely by user asking code on screen with calling number
Not entering in ODIN mode neither reset mode
if I try reset via TP with unlock tool i get this error
[BROM] FACTORY RESET Initializing usb... OK
Waiting for device... COM5 [BOOTROM:0E8D:0003]
Bypassing authentication... OK
Analyzing... preloader_k6853v1_64_titan.bin [MT6853:11:1036] [Internal]
Vendor : SAMSUNG
Reading hardware info... OK
Hardware : MT6853 [Dimensity 720|800U] 0996 8A00 CA00 0000
Security Config : SCB SLA DAA
MEID : 750BC3CA352C2728F93F6D49D0B542F1
Sending Download-Agent... OK
Syncing with target... OK
Booting device... OK
Syncing with DA... OK
Storage : UFS - FWVer : 0007 - CID : MT128GASAO4U219K
Vendor ID : Micron [0x12C]
UFS: LU0 Size : 4 MiB - LU1 Size : 4 MiB - LU2 Size : 119,17 GiB
Reading partition info... OK [56]
Reading device info... OK
Model Name : SM-A326B
Product Name : a32xxx
Manufacturer : samsung
Platform : k6853v1_64_titan
Android Version : 11
Security Patch : 2021-10-01
Build ID : RP1A.200720.012.A326BXXS3AUJ5
Build : A326BXXS3AUJ5
Build Date : Mon Oct 18 14:04:24 KST 2021
PDA : A326BXXS3AUJ5
Erasing USERDATA... FAIL
Status : Invalid GPT! Status code : 0xC0030008
UNLOCKTOOL 2022.11.08.0
Elapsed time : 20 seconds
any solution plz
WBR
Wasim
Old 11-09-2022, 13:30   #2 (permalink)
wykie's Avatar
Member: 36126
Thanks Meter: 310
Hi
is there any way to get it done ?
please let me know
thanks
wbr
wasim
Old 11-10-2022, 01:45   #3 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,564
Originally Posted by wykie View Post
Hi
please let me know
thanks
wbr
wasim
JTAG (to erase user data) or board swap.
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
Old 11-14-2022, 00:33   #4 (permalink)
wykie's Avatar
Member: 36126
Thanks Meter: 310
Hi
Phone dead now not flashing the scatter file i get GPT INVALID error
FLASH Initializing usb... OK
Waiting for device... COM10 [BOOTROM:0E8D:0003]
Vendor : SAMSUNG
Tips : GPT not initialized! Using scatter as partition map!
Writing preloader_k6853v1_64_titan.bin [333,81 KiB] -> preloader [512 KiB]... OK
Writing preloader_k6853v1_64_titan.bin [333,81 KiB] -> preloader_backup [512 KiB]... OK
Writing uh.img [136,95 KiB] -> uh [256 KiB]... FAIL
Writing tzar.img [2,9 MiB] -> tzar [512 KiB]... FAIL
Writing dtbo.img [564,55 KiB] -> dtbo [1 MiB]... FAIL
Writing vbmeta.img [7,94 KiB] -> vbmeta [8 KiB]... FAIL
Writing misc.img [508,5 KiB] -> misc [64 KiB]... FAIL
Writing metadata.img [52,11 KiB] -> metadata [4 MiB]... FAIL
Writing md1img.img [52,09 MiB] -> md1img [25 MiB]... FAIL
Writing param.img [120,5 KiB] -> param [512 KiB]... FAIL
Writing up_param.img [1,7 MiB] -> up_param [512 KiB]... FAIL
Writing boot.img [32 MiB] -> boot [4 MiB]... FAIL
Writing recovery.img [40 MiB] -> recovery [5 MiB]... FAIL
Writing vbmeta_system.img [3,31 KiB] -> vbmeta_system [8 KiB]... FAIL
Writing efuse.img [1 KiB] -> efuse [64 KiB]... FAIL
Writing super.img [6,25 GiB] -> super [937,5 MiB]... FAIL
Writing prism.img [583,64 MiB] -> prism [87,5 MiB]... FAIL
Writing optics.img [3,09 MiB] -> optics [3 MiB]... FAIL
Writing cache.img [64,14 KiB] -> cache [25 MiB]... FAIL
Writing omr.img [52,11 KiB] -> omr [6,25 MiB]... FAIL
Writing userdata.img [1,23 GiB] -> userdata [0 byte]... FAIL
UNLOCKTOOL 2022.11.11.1
Elapsed time : 39 second
when i try to restore NV file software crush and gets crash n close
Need your help plz
WBR
Wasim
Old 11-14-2022, 14:13   #5 (permalink)
wykie's Avatar
Member: 36126
Thanks Meter: 310
Hi
can anyone please share Samsung A326B dump file ? may be that can help
Thanks in advance
WBR
Old 11-14-2022, 23:04   #6 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,564
... all you should do, was testpoint and flash factory flash in odin mode.
now ... just problems.
b.r.
Alex
__________________
Old 11-16-2022, 22:52   #7 (permalink)
wykie's Avatar
Member: 36126
Thanks Meter: 310
Hi
It would be great if somwone can help me out
or share what can i do in this case
mobile enters in BROM mode or may be its in BROM always
an i connect battery and connect the cable MTK drivers comes and go and eep doing like this
if i connect with TP it stays in that mode
Thanks in advance
WBR
Wasim
Old 11-23-2022, 23:45   #8 (permalink)
wykie's Avatar
Member: 36126
Thanks Meter: 310
Hi,,
I am trying to flash mobile but program crash n close when it comes to Reading phone info , in any task its doing the same if i try Bootloader remove option it stops and close when it comes to Reading phone info
please if you can help me
Thanks
Old 03-06-2023, 15:42   #9 (permalink)
SAEIDSANGAN's Avatar
Member: 1691551
Sonork: 100.1622582
Thanks Meter: 53
i replace this model ufs chip
read from old ufs to new
show download mode but give error flash with odin
failed super partition
anyone can help me?
Page generated in 0.14891 seconds with 9 queries
