04-25-2022, 01:10 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: GRAN ALACANT SPAIN
Member: 1147852 Status: Offline Thanks Meter: 587 | Failed operation series : Xiaomi mct8 mi account reset failed Code Name : Jason Operation : Disable OTA Update **Authenticating... OK **Retrieving data... FAIL UNLOCKTOOL 2022.04.19.0 Elapsed time : 27 seconds DONE WITH OTHER TOOL / SAME PC / SAME DRIVERS / SAME CABLE ONE MONTH OF USE 2 OPERATION SUCCESS ONLY |
The Following User Says Thank You to Punto-Móvil For This Useful Post: |
04-27-2022, 22:29 | #2 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | 2 things .... 1st: On "other tool you also cant "disable ota" 2nd: You should just select : EDL - RESET | DISABLE MI CLOUD all would work normal, as it is working normal. p.s. Just finished one MI device, all works perfectly normal that described way. Of course on first startup, it's mandatory to untick "Update system automatically" and inform cusotmers that it is a bypass, and that updating will revert it to locked state, as would happen with phones unlocked by any other "tool" / "box". b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
