03-02-2023, 20:24 | #1 (permalink) |
Freak Poster Join Date: Jul 2017
Member: 2738165 Status: Offline Thanks Meter: 23 | Iphone 5SE turns on sending ibss/ibec I have with me a passcode locked iphone 5SE. It's on IOS 14, however, the client doesn't want to upgrade the firmware. When I select "IOS 14.X.X RAMDISK" I get the error. However, if I select "File Gaster Ramdisk 15.x 5SE-6S-6SP-7G-7P" It boots the ramdisk okay but unable to mount the data. Therefore, I am not able to backup the passcode. I tried holding down the volume-down+Power button but to no avail. Could someone please be kind and provide me with a link for the generic ramdisk ? |
03-03-2023, 17:49 | #2 (permalink) |
Member: 2738165 Status: Offline Thanks Meter: 23 | Could someone please post a link for the old RAMDISK loader? I realize that the unlocktool Team removed OLD RAMDISK loader from download. The new loaders are not working properly! Thanks in advance! |
03-04-2023, 22:11 | #3 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,787 | Quote:
the real solution for your device is jailbreak - make backup - erase - jailbreak again - restore b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
03-06-2023, 15:34 | #4 (permalink) | |
Member: 2738165 Status: Offline Thanks Meter: 23 | Quote:
The iPhone 5SE is on ios 14.5. Sure, I could go ahead and jailbreak and do a passcode backup. However, it would remove the possibility of updating to ios 15 with the passcode backup. Hence, the reason why I'm doing the ramdisk bypass. iOS 14.X.X RAMDISK boots device when sending ibss/ ibec & and the old ramdisk load them fine only failed to load recovery mode. Please see results below: iOS 14.X.X RAMDISK BOOT RAMDISK Checking for device... OK Info : iPhone SE [iPhone8,4-n69ap] Boot : [IBOOT-2234.0.0.2.22] [DFU] Pwnder : GASTER Initializing... OK Sending ibss.img4... OK Sending ibec.img4... FAIL ERROR: Unable to connect to device Tips : If device keeps booting up while sending ibss or ibec Press and Hold VOLUME DOWN + POWER while sending ibss and ibec After done sending ibss and ibec you can release those buttons. UNLOCKTOOL 2023.02.28.0 Elapsed time : 45 seconds ------------------------------------------------------------------------ OLD RAMDISK BOOT RAMDISK Checking for device... OK Info : iPhone SE [iPhone8,4-n69ap] Boot : [IBOOT-2234.0.0.2.22] [DFU] Pwnder : GASTER Initializing... OK Sending ssh... OK Sending ibss.img4... OK Sending ibec.img4... OK Executing loader... OK Sending devicetree.img4... OK Sending ramdisk.img4... OK Sending kernel.img4... OK Booting RAMDISK... FAIL Recovery Mode UNLOCKTOOL 2023.02.28.0 Elapsed time : 42 seconds --------------------------------------------------------------------------------- | |
03-07-2023, 02:47 | #5 (permalink) | |
Jailbreak - backup - erase - restore backup, after done - update with retain data option from 3uTools to latest version. b.r. Alex
03-07-2023, 22:36 | #6 (permalink) | |
There is no jailbreak for iOS 15 at this time that would like passcode restore for ios 15. | |
03-09-2023, 00:01 | #7 (permalink) | |
after that no need to do restore again, just upgrade with RETAIN DATA in 3uTools, bypass will stay. Dont forget to do Disable Reset + OTA ... that way customer cant break bypass. p.s. After done ... you can try booting Ramdisk, to check if it works. If it works normal, you can again fully erase (full flash) and restore backup, if you want to play. b.r. Alex
