Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > UnlockTool
Old 02-10-2024, 12:23   #1 (permalink)
Member: 9568
Thanks Meter: 209
Xiaomi Mi10t lite 5G Mi account remove
Hi,
Is there any solution for mi account remove from Mi10t lite 5G?
[SIDELOAD] RESET | DISABLE MI CLOUD Starting ADB Interface... OK
Connecting to device... OK
Connection Mode : sideload
Product Model : Gauguin
Product Name : gauguin_eea
Device Name : gauguin
Device Name : gauguin_eea_global
Firmware Version : V12.0.8.0.QJSEUXM
Android Version : 10
Language : hr
Region : HR
Recovery Version : 2
Device Serial : 0x0bbacb29
ROM Zone : 2
Initializing... OK
Reseting MiCloud... FAIL
Failed to read MiCloud! Firmware is not support!
Disabling MiCloud... FAIL
Failed to read SEC data!
UNLOCKTOOL 2024.01.27.0
Elapsed time : 12 seconds
I'm try to unlock from sideload and with testpoint EDL, but without success.
Any help?
Thank You!
Old 02-16-2024, 11:16   #2 (permalink)
topline's Avatar
Member: 85139
Thanks Meter: 68
idem problem
Language : it
Region : IT
Device Serial : 0x888cf603
ROM Zone : 2
Initializing... OK
Elapsed time : 16 seconds
Originally Posted by Bmt_HR View Post
Hi,
Language : hr
Region : HR
ROM Zone : 2
Initializing... OK
Any help?
Thank You!
Old 02-16-2024, 12:38   #3 (permalink)
Member: 172567
Thanks Meter: 90
you didn't put a log of the process by testpoint to check the error.
Old 02-16-2024, 23:30   #4 (permalink)
topline's Avatar
Member: 85139
Thanks Meter: 68
my model is M2007J17G
[EDL] RESET | DISABLE MI CLOUD Selected Model : Xiaomi Redmi Note 10
Code Name : mojito | sunny
Operation : Reset MiCloud [2]
**Authenticating... OK
**Retrieving data... OK [293,87 KiB]
Initializing data... OK
Waiting for HS-USB QDLoader 9008... COM12
Handshaking... OK
Reading bootloader info... OK
**Serial : 2290939395 SoC : [] [] [0x001630E1]
**OEM : Xiaomi [0x0072] Model : Unknown [0x0000]
**PK_HASH[0] : 1BEBE3863A6781DB4B01086063007334
**PK_HASH[1] : DE9E5CA14971C7C4F4358EC9D79CDA46
Writing flash programmer... FAIL
[Sahara] Image Load - Firehose does not match this device!
Trying to connect to FIREHOSE Mode!
Connecting to flash programmer... FAIL
Waiting for response timeout!
Elapsed time : 25 seconds
Old 02-19-2024, 12:25   #5 (permalink)
Member: 172567
Thanks Meter: 90
It's "Gauguin", it will never work with the Mojito/sunny loader, it'ss only for that model. The only option I guess is try twith xiao mi tool v2 to check if it allows an update in sideload with android 11 (miui 12.5 or 13, don't put the 14), download that file, flash it with their sideload tool, and then you can bypass by sideload. But it will depend of the phone and the xiaomi sever (all that updates goes by their check). Or you can update it by testpoint but I don't know if it will ask for authorize.
The Following User Says Thank You to cartuchobahia For This Useful Post:
Old 02-19-2024, 12:32   #6 (permalink)
Member: 172567
Thanks Meter: 90
There's no tool that supports that model by testpoint (it only works for flash), and sideload only works for android 11 and some early versions of android 12. The free tool that I suggestes will not allow to flash any flash, it will tell you the ones allowed by xiaomi server. Normally flashing by sideload will skip the authorization that you got in fastboot mode, it's like a normal update of the phone
Old 02-19-2024, 16:22   #7 (permalink)
topline's Avatar
Member: 85139
Thanks Meter: 68
flash firmware
good morning, to update the firmware...What software do I use to write the firmware (gauguin_global_images_V14.0.2.0.SJSMIXM_20230421. 0000.00_12.0_global) ..where can I download it? thanks
Old 02-19-2024, 17:20   #8 (permalink)
Member: 172567
Thanks Meter: 90
Really? I'd gived you the name of the program to try (you have the way to use on the website where you can download and several videos in youtube). I recomended you to don't use the 14.0 cos not all the android 12 are supported to bypass in sideload. And there's several free sites to download firmware. Google a little bit, I'd allready tried to help.
Old 02-19-2024, 23:44   #9 (permalink)
topline's Avatar
Member: 85139
Thanks Meter: 68
thanks
thanks, but xia omi tool 2 doesn't have my model...mi10t lite 5G, I can't figure out how to do it
Page generated in 0.17512 seconds with 8 queries
