02-18-2023, 19:25 | #1 (permalink) |
Insane Poster Join Date: Feb 2004 Location: Batam Age: 52
Member: 52362 Status: Offline Thanks Meter: 35 | Xiaomi POCO M4 Pro (Fleur) dual imei repair successfull Verifying user information. Successful Program version : 1.0.5.2 Process name : Mtk Imei Repair (Meta and Flash Methot) Process model name : Xiaomi Redmi Note 11S 4G-POCO M4 Pro 4G (fleur) Load from library. Succesfuly Setting up the library. Succesfuly LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port_V1633 Number : 11 Path : \\.\usb#vid_0e8d&pid_0003#5&1c2b5ac6&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6781 (Helio G96) Hardware code : 0x00001066 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Active DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : 3E85F772E0407D0B81904B92ACB38214 Get socid. Succesfuly Meid : 3973EB92B73185D0B8432DDE2F72CF8045737F5062AE7925AB 3DCD1669515A2A Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_fleur.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 384 KB (0x0000000000200000) DRAM size : 384 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : uFS Disk size : 119,17 GB Disk cid : MT128GAXAU2U22 Check storage life. Succesfuly Reading device partition. Succesfuly Part count : 60 Download protocol start. Succesfuly Reading device information. Succesfuly Brand name : Redmi Model name : fleur Release : 12 Security version : 2022-09-01 Display id : SP1A.210812.016 Date : 1662470896 Description : fleur-user 12 SP1A.210812.016 V13.0.6.0.SKEMIXM release-keys Cpu version : arm64-v8a Locale : en-GB Id : SP1A.210812.016 Backup nvram file. Succesfuly Backup count : 8 Path : C:\Program Files (x86)\Tr Tools PRO\Backup\Mtk\Calibration\Flash Mode\Redmi Note 11S 4G-POCO M4 Pro 4G (fleur)-2023-02-19-01-20-22.tr Clear calibration data. Succesfuly Backup cert. Original backup file found. Patch cert. Succesfuly Patch vbmeta : Succesfuly Device bootloader encryption is calculated from server. Succesfuly Download protocol finish. Succesfuly Reboot device. Succesfuly LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port_V1633 Number : 11 Path : \\.\usb#vid_0e8d&pid_0003#5&1c2b5ac6&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6781 (Helio G96) Hardware code : 0x00001066 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Active DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : 3E85F772E0407D0B81904B92ACB38214 Get socid. Succesfuly Meid : 3973EB92B73185D0B8432DDE2F72CF8045737F5062AE7925AB 3DCD1669515A2A Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reboot brom to meta mode. Succesfuly Waiting meta port. Found. Connect meta protocol. Succesfuly Get modem information. Succesfuly Read build information. Succesfuly Brand name : POCO Model name : 2201117PG Release : 12 Display id : SP1A.210812.016 Date : Tue Sep 6 21:28:16 CST 2022 Description : fleur-user 12 SP1A.210812.016 V13.0.6.0.SKEMIXM release-keys Manufacturer : Xiaomi Read meta information. Succesfuly Chip name : MT6781 Sw time : Tue Sep 6 21:28:16 CST 2022 S/W version : alps-mp-s0.mp1.tc8sp-mt6785-V1.12_xiaomi.s0mp1.k85v1.64_P42 Build version : SP1A.210812.016 Upload database. Succesfuly Load database. Succesfuly Reading imei number. Succesfuly 1. Imei number : 000000000000000 2. Imei number : 000000000000000 Backup nvram file. Succesfuly Save path : C:\Program Files (x86)\Tr Tools PRO\Backup\Mtk\Calibration\Flash Mode\Redmi Note 11S 4G-POCO M4 Pro 4G (fleur)-2023-02-19-01-20-22.tr First imei repair. Succesfuly Second imei repair. Succesfuly Reboot to normal. Succesfuly Process status : Successful Process time : 86 .s Process number : 4810713 Note : This is MIUI 13.0.6.0 (global rom) |
The Following User Says Thank You to GSM_STARCOM For This Useful Post: |
