07-27-2022, 17:11 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: EARTH
Member: 259397 Status: Offline Thanks Meter: 76 | f5 cph1723 imei repair failed Program version : 1.0.4.3 Process name : Mtk Imei Repair (Adb and Flash Methot) Process model name : Oppo F5 (CPH1723) Waiting adb connection. Found. Port Information : Name : Android Composite ADB Interface Path : \\.\usb#vid_22d9&pid_2772&mi_01#7&595ca44&0&0001#{ f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} Open adb path. Succesfuly Check adb connection. Succesfuly Reading device information. Succesfuly Brand name : OPPO Model name : CPH1723 Release : 7.1.1 Security version : 2017-10-05 Display id : CPH1723EX_11_A.07_171116 Date : 201711162246 Description : full_oppo6763_17031-user 7.1.1 N6F26Q 1510852707 release-keys Cpu version : arm64-v8a Locale : en-US Id : N6F26Q Serial number : OFY559LNJNMZINKJ Frp partition : /dev/block/platform/bootdevice/by-name/frp LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port Number : 38 Path : \\.\usb#vid_0e8d&pid_0003#6&24385ce2&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6763 (Helio P23) Hardware code : 0x00000690 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Passive DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : C2DFC4609004DB2D57B40BBC94D8D4E4 Get socid. Succesfuly Meid : 027C1BE84D464146A68B5496B68D0A9A04322B12B8E5AA132F 0D76554FB949AF Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_oppo6763_17031.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 256 KB (0x0000000000200000) DRAM size : 256 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : eMMC Disk size : 58.24 GB Disk cid : RH64M Check storage life. Succesfuly Reading device partition. Succesfuly Part count : 40 Download protocol start. Succesfuly Clear calibration data. Succesfuly Download protocol finish. Succesfuly Reboot device. Succesfuly Waiting adb connection. Found. Port Information : Name : Android Composite ADB Interface Path : \\.\usb#vid_22d9&pid_2772&mi_01#7&595ca44&0&0001#{ f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} The device is expected to be ready. Succesfuly LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port Number : 38 Path : \\.\usb#vid_0e8d&pid_0003#6&24385ce2&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6763 (Helio P23) Hardware code : 0x00000690 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Passive DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : C2DFC4609004DB2D57B40BBC94D8D4E4 Get socid. Succesfuly Meid : 027C1BE84D464146A68B5496B68D0A9A04322B12B8E5AA132F 0D76554FB949AF Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_oppo6763_17031.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 256 KB (0x0000000000200000) DRAM size : 256 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : eMMC Disk size : 58.24 GB Disk cid : RH64M Check storage life. Succesfuly Reading device partition. Succesfuly Part count : 40 Download protocol start. Succesfuly Fast methot init. The method was not successful Process status : Error Process time : 119 .s Process number : 1334000 |
