11-13-2022, 15:19 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: EARTH
Member: 259397 Status: Offline Thanks Meter: 76 | oppo cph1945 repair fialed Program version : 1.0.5.1 Process name : Mtk Imei Repair (Adb and Flash Methot) Process model name : Oppo Reno 2Z (CPH1945) Waiting adb connection. Found. Port Information : Name : Android Composite ADB Interface Path : \\.\usb#vid_22d9&pid_2765&mi_01#7&6897a9b&0&0001#{ f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} Open adb path. Succesfuly Check adb connection. Succesfuly Reading device information. Succesfuly Brand name : OPPO Model name : CPH1945 Release : 11 Security version : 2022-08-05 Display id : CPH1945_11_F.65_220727 Date : 1658916813 Description : sys_oplus_mssi_64_cn-user 11 RP1A.200720.011 1658913016668 release-keys Cpu version : arm64-v8a Locale : en-US Id : RP1A.200720.011 Serial number : DEPZ7SSKGMQ4EU5P Security partition : nvram,nvdata Frp partition : /dev/block/by-name/frp LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port Number : 81 Path : \\.\usb#vid_0e8d&pid_0003#6&17706c76&0&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6779 (Helio P90 k79v1) Hardware code : 0x00000725 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Passive DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : B0FFBF5E7562BDBF317147906E2AEF97 Get socid. Succesfuly Meid : F0FC12EEB77F5F49362F6C4196A9413F7998145B31339A6109 FB6498B70E8D7E Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_oppo6779.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Error found. Error information and Solition suggestions Function name : MtkSetFlashMode Error number : 1 Solition : 1. Your transaction may be left unfinished. 2. The memory chip may be faulty. 3. Protocol may not be supported. Process status : Error Process time : 49 .s Process number : 3200394 i also try unlock bootloader but same err i try an aother tool to unlock bootloader mobile connect successfully bootloaer unlock sucess but in tr tool always stuck on this err Set flash mode device. Error found. |
The Following User Says Thank You to Tanveer_city01 For This Useful Post: |
