12-07-2022, 09:24 | #1 (permalink) |
Insane Poster Join Date: Feb 2004 Location: Batam Age: 52
Member: 52362 Status: Offline Thanks Meter: 35 | Oppo Reno 3 pro (CPH2035) repair imei problem I did imei repair with open bootloader and the phone is stuck on the logo, after restarting it only boots in recovery Verifying user information. Successful Program version : 1.0.5.2 Process name : Mtk Imei Repair (Adb and Flash Methot) Process model name : Oppo Reno 3 Pro (CPH2035) Waiting adb connection. Found. Port Information : Name : Android Composite ADB Interface Path : \\.\usb#vid_22d9&pid_2765&mi_01#7&375ba226&0&0001# {f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} Open adb path. Succesfuly Check adb connection. Succesfuly Reading device information. Succesfuly Brand name : OPPO Model name : CPH2037 Release : 11 Security version : 2022-03-05 Display id : CPH2035_11_C.23_220304 Date : 1646413736 Description : sys_oplus_mssi_64_cn-user 11 RP1A.200720.011 1646410489222 release-keys Cpu version : arm64-v8a Locale : en-US Id : RP1A.200720.011 Serial number : LN75EYLJYSCUHYCY Security partition : nvram,nvdata Frp partition : /dev/block/by-name/frp Build version : 1646410489222 LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port_V1632 Number : 19 Path : \\.\usb#vid_0e8d&pid_0003#6&1acfd2d8&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6779 (Helio P90 k79v1) Hardware code : 0x00000725 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Passive DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : 15B54C848BA29AC1B96B2C021E7DDFF9 Get socid. Succesfuly Meid : 009ED845BC36177893775A16DD93761DC43C719DC32435C54F 4774C6FBCF9596 Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_oppo6779.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 512 KB (0x0000000000200000) DRAM size : 512 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : uFS Disk size : 238,34 GB Disk cid : KM8B8001JM-BC0 Check storage life. Succesfuly Reading device partition. Succesfuly Part count : 53 Download protocol start. Succesfuly Backup nvram file. Succesfuly Backup count : 3 Path : C:\Program Files (x86)\Tr Tools PRO\Backup\Mtk\Calibration\Flash Mode\Reno 3 Pro (CPH2035)-2022-12-07-15-20-57.tr Clear calibration data. Succesfuly Download protocol finish. Succesfuly Reboot device. Succesfuly Waiting adb connection. Found. Port Information : Name : Android ADB Interface Path : \\.\usb#vid_22d9&pid_2769#ln75eyljyscuhycy#{f72fe0 d4-cbcb-407d-8814-9ed673d0dd6b} The device is expected to be ready. Succesfuly LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port_V1632 Number : 19 Path : \\.\usb#vid_0e8d&pid_0003#6&1acfd2d8&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6779 (Helio P90 k79v1) Hardware code : 0x00000725 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Passive DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : 15B54C848BA29AC1B96B2C021E7DDFF9 Get socid. Succesfuly Meid : 009ED845BC36177893775A16DD93761DC43C719DC32435C54F 4774C6FBCF9596 Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_oppo6779.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 512 KB (0x0000000000200000) DRAM size : 512 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : uFS Disk size : 238,34 GB Disk cid : KM8B8001JM-BC0 Check storage life. Succesfuly Reading device partition. Succesfuly Part count : 53 Download protocol start. Succesfuly Fast methot init. Succesfuly First imei calculation from server. Succesfuly Second imei calculation from server. Succesfuly The calculated file is written to the device. Succesfuly Patch cert. Succesfuly Download protocol finish. Succesfuly Reboot device. Succesfuly Process status : Successful Process time : 172 .s Process number : 3641275 |
The Following User Says Thank You to GSM_STARCOM For This Useful Post: |
12-20-2022, 10:07 | #2 (permalink) | |
Banned Join Date: Aug 2021 Location: Turkey Age: 29
Member: 2995173 Status: Offline Thanks Meter: 471 | Quote:
