12-15-2022, 09:23 | #47 (permalink) |
Insane Poster Join Date: Feb 2004 Location: Batam Age: 52
Member: 52362 Status: Offline Thanks Meter: 35 | Oppo F11 pro CPH1969 imei repair done here logs : Verifying user information. Successful Program version : 1.0.5.2 Process name : Mtk Imei Repair (Adb and Flash Methot) Process model name : Oppo F11 Pro (CPH1969) Waiting adb connection. Found. Port Information : Name : Android Composite ADB Interface Path : \\.\usb#vid_22d9&pid_2765&mi_01#7&328aa053&0&0001# {f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} Open adb path. Succesfuly Check adb connection. Succesfuly Reading device information. Succesfuly Brand name : OPPO Model name : CPH1969 Release : 10 Security version : 2020-02-05 Display id : CPH1969EX_11_C.29_00000000 Date : 1598371595 Description : full_oppo6771-user 10 QP1A.190711.020 d382deafd7252416 release-keys Cpu version : arm64-v8a Locale : en-US Id : QP1A.190711.020 Serial number : S4HUWKUKSGMRINKV Security partition : nvram,nvdata Frp partition : /dev/block/platform/bootdevice/by-name/frp Build version : 1595992587 LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port_V1632 Number : 19 Path : \\.\usb#vid_0e8d&pid_0003#6&1acfd2d8&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6771/MT8385/MT8183/MT8666 (Helio P60/P70/G80) Hardware code : 0x00000788 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Passive DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : 6DE7F79940B9E933FC67659CB809CFDB Get socid. Succesfuly Meid : 552259161CAB495C042FA44639245D4B39CECF255625503E13 8969E65644E883 Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_oppo6771.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 228 KB (0x0000000000200000) DRAM size : 228 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : eMMC Disk size : 58,24 GB Disk cid : 3H6CA Check storage life. Succesfuly Reading device partition. Succesfuly Part count : 44 Download protocol start. Succesfuly Backup nvram file. Succesfuly Backup count : 3 Path : C:\Program Files (x86)\Tr Tools PRO\Backup\Mtk\Calibration\Flash Mode\F11 Pro (CPH1969)-2022-12-15-15-19-32.tr Clear calibration data. Succesfuly Download protocol finish. Succesfuly Reboot device. Succesfuly Waiting adb connection. Found. Port Information : Name : Android ADB Interface Path : \\.\usb#vid_22d9&pid_2769#s4huwkuksgmrinkv#{f72fe0 d4-cbcb-407d-8814-9ed673d0dd6b} The device is expected to be ready. Succesfuly LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port_V1632 Number : 19 Path : \\.\usb#vid_0e8d&pid_0003#6&1acfd2d8&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6771/MT8385/MT8183/MT8666 (Helio P60/P70/G80) Hardware code : 0x00000788 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Passive DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : 6DE7F79940B9E933FC67659CB809CFDB Get socid. Succesfuly Meid : 552259161CAB495C042FA44639245D4B39CECF255625503E13 8969E65644E883 Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_oppo6771.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 228 KB (0x0000000000200000) DRAM size : 228 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : eMMC Disk size : 58,24 GB Disk cid : 3H6CA Check storage life. Succesfuly Reading device partition. Succesfuly Part count : 44 Download protocol start. Succesfuly Fast methot init. Succesfuly First imei calculation from server. Succesfuly Second imei calculation from server. Succesfuly The calculated file is written to the device. Succesfuly Patch cert. Succesfuly Download protocol finish. Succesfuly Reboot device. Succesfuly Process status : Successful Process time : 270 .s |
12-15-2022, 09:52 | #48 (permalink) |
Member: 52362 Status: Offline Thanks Meter: 35 | Redmi 9A dandelion imei repair done Verifying user information. Successful Program version : 1.0.5.2 Process name : Mtk Imei Repair (Flash Mode (Dual Sim)) Process model name : Xiaomi Redmi 9A-Redmi 10A-10A Sport-9AT-9i-9A Sport (dandelion) LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port_V1632 Number : 19 Path : \\.\usb#vid_0e8d&pid_0003#6&1acfd2d8&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6765 (Helio P35/G35) Hardware code : 0x00000766 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Active DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : AE2AD3CF44395A8FF7537C1DA05959AC Get socid. Succesfuly Meid : 805D614A1B8888C74416E4ECF9E73876B3215E943D15BE4598 A6D2D54A476334 Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Reading list from server. Succesfuly File is approved from the server. Succesfuly Downloading file. Succesfuly File is being verified. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_k62v1_64_bsp.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 232 KB (0x0000000000200000) DRAM size : 232 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : eMMC Disk size : 29,12 GB Disk cid : DA403 Check storage life. Succesfuly Reading device partition. Succesfuly Part count : 43 Download protocol start. Succesfuly Reading device information. Succesfuly Brand name : Redmi Model name : dandelion Release : 10 Security version : 2020-11-01 Display id : QP1A.190711.020 Date : 1606224670 Description : dandelion-user 10 QP1A.190711.020 V12.0.9.0.QCDEUXM release-keys Locale : en-GB Id : QP1A.190711.020 Backup nvram file. Succesfuly Backup count : 7 Path : C:\Program Files (x86)\Tr Tools PRO\Backup\Mtk\Calibration\Flash Mode\Redmi 9A-Redmi 10A-10A Sport-9AT-9i-9A Sport (dandelion)-2022-12-15-15-51-15.tr Reading imei number. Succesfuly 1. Imei number : 868955050386321 2. Imei number : 868955051176366 Fast methot init. Succesfuly First imei calculation from server. Succesfuly Second imei calculation from server. Succesfuly The calculated file is written to the device. Succesfuly Backup cert. Error found. Patch cert. Succesfuly Patch vbmeta : Succesfuly Device bootloader encryption is calculated from server. Succesfuly Download protocol finish. Succesfuly Reboot device. Succesfuly Process status : Successful Process time : 94 .s Process number : 3789500 |
12-17-2022, 08:35 | #49 (permalink) |
Member: 52362 Status: Offline Thanks Meter: 35 | Realme C11 rmx2185 imei repair success Verifying user information. Successful Program version : 1.0.5.2 Process name : Mtk Imei Repair (Adb and Flash Methot) Process model name : Realme C11 (RMX2185) Waiting adb connection. Found. Port Information : Name : Android Composite ADB Interface Path : \\.\usb#vid_22d9&pid_2765&mi_01#7&ef75796&0&0001#{ f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} Open adb path. Succesfuly Check adb connection. Succesfuly Reading device information. Succesfuly Brand name : realme Model name : RMX2185 Release : 10 Security version : 2022-08-05 Display id : RMX2185_11_A.109_00000000 Date : 1659349418 Description : full_oppo6765-user 10 QP1A.190711.020 bedd37e98646d3a1 release-keys Cpu version : arm64-v8a Locale : en-US Id : QP1A.190711.020 Serial number : 7H7PCMOB75YTVKPV Security partition : nvram,nvdata Frp partition : /dev/block/platform/bootdevice/by-name/frp Build version : 1658568104 LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port_V1632 Number : 19 Path : \\.\usb#vid_0e8d&pid_0003#6&1acfd2d8&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6765 (Helio P35/G35) Hardware code : 0x00000766 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Passive DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : 38C138EA146FB0CCF6D830B06B8454BF Get socid. Succesfuly Meid : D3A5F8494EA19C496368C9C2705656F25002F4A72940885EF0 B8E5B6DFC30D41 Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_oppo6765.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 232 KB (0x0000000000200000) DRAM size : 232 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : eMMC Disk size : 29,12 GB Disk cid : JhB8aP Check storage life. Succesfuly Reading device partition. Succesfuly Part count : 47 Download protocol start. Succesfuly Backup nvram file. Succesfuly Backup count : 3 Path : C:\Program Files (x86)\Tr Tools PRO\Backup\Mtk\Calibration\Flash Mode\C11 (RMX2185)-2022-12-17-14-31-31.tr Clear calibration data. Succesfuly Download protocol finish. Succesfuly Reboot device. Succesfuly Waiting adb connection. Found. Port Information : Name : Android ADB Interface Path : \\.\usb#vid_22d9&pid_2769#7h7pcmob75ytvkpv#{f72fe0 d4-cbcb-407d-8814-9ed673d0dd6b} The device is expected to be ready. Succesfuly LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port_V1632 Number : 19 Path : \\.\usb#vid_0e8d&pid_0003#6&1acfd2d8&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6765 (Helio P35/G35) Hardware code : 0x00000766 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Passive DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : 38C138EA146FB0CCF6D830B06B8454BF Get socid. Succesfuly Meid : D3A5F8494EA19C496368C9C2705656F25002F4A72940885EF0 B8E5B6DFC30D41 Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_oppo6765.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 232 KB (0x0000000000200000) DRAM size : 232 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : eMMC Disk size : 29,12 GB Disk cid : JhB8aP Check storage life. Succesfuly Reading device partition. Succesfuly Part count : 47 Download protocol start. Succesfuly Fast methot init. Succesfuly First imei calculation from server. Succesfuly Second imei calculation from server. Succesfuly The calculated file is written to the device. Succesfuly Patch cert. Succesfuly Download protocol finish. Succesfuly Reboot device. Succesfuly Process status : Successful Process time : 207 .s Process number : 3825601 |
12-17-2022, 08:47 | #50 (permalink) |
Member: 52362 Status: Offline Thanks Meter: 35 | Redmi note 11S miel dual imei repair success Verifying user information. Successful Program version : 1.0.5.2 Process name : Mtk Imei Repair (Meta and Flash Methot) Process model name : Xiaomi Redmi Note 11S 4G-POCO M4 Pro 4G (miel) Load from library. Succesfuly Setting up the library. Succesfuly LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port_V1632 Number : 19 Path : \\.\usb#vid_0e8d&pid_0003#6&1acfd2d8&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6781 (Helio G96) Hardware code : 0x00001066 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Active DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : D0BDBB011376332E8ACDF1A4A824E64E Get socid. Succesfuly Meid : 77B358F2CDD27E8BFB7ADD0C5B71BEDEAA54ADF71A7CD88B4A 8656A935A9AF76 Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_fleur.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 384 KB (0x0000000000200000) DRAM size : 384 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : uFS Disk size : 119,17 GB Disk cid : KM8L9001JM-B62 Check storage life. Succesfuly Reading device partition. Succesfuly Part count : 60 Download protocol start. Succesfuly Reading device information. Succesfuly Brand name : Redmi Model name : fleur Release : 11 Security version : 2021-12-01 Display id : RP1A.200720.011 Date : 1640887210 Description : fleur-user 11 RP1A.200720.011 V13.0.1.0.RKEMIXM release-keys Cpu version : arm64-v8a Locale : en-GB Id : RP1A.200720.011 Backup nvram file. Succesfuly Backup count : 8 Path : C:\Program Files (x86)\Tr Tools PRO\Backup\Mtk\Calibration\Flash Mode\Redmi Note 11S 4G-POCO M4 Pro 4G (miel)-2022-12-17-14-44-05.tr Clear calibration data. Succesfuly Backup cert. Original backup file found. Patch cert. Succesfuly Patch vbmeta : Succesfuly Device bootloader encryption is calculated from server. Succesfuly Download protocol finish. Succesfuly Reboot device. Succesfuly LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port_V1632 Number : 19 Path : \\.\usb#vid_0e8d&pid_0003#6&1acfd2d8&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6781 (Helio G96) Hardware code : 0x00001066 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Active DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : D0BDBB011376332E8ACDF1A4A824E64E Get socid. Succesfuly Meid : 77B358F2CDD27E8BFB7ADD0C5B71BEDEAA54ADF71A7CD88B4A 8656A935A9AF76 Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reboot brom to meta mode. Succesfuly Waiting meta port. Found. Connect meta protocol. Succesfuly Get modem information. Succesfuly Read build information. Succesfuly Brand name : Redmi Model name : 2201117SG Release : 11 Display id : RP1A.200720.011 Date : Fri Dec 31 02:00:10 CST 2021 Description : fleur-user 11 RP1A.200720.011 V13.0.1.0.RKEMIXM release-keys Manufacturer : Xiaomi Read meta information. Succesfuly Chip name : MT6781 Sw time : Fri Dec 31 02:00:10 CST 2021 S/W version : alps-mp-r0.mp8.tc8sp3-mt6781-V1.5.1_lcsh.xm.r0mp8.k6781v1.64_P33 Build version : RP1A.200720.011 Upload database. Succesfuly Load database. Succesfuly Reading imei number. Succesfuly 1. Imei number : 000000000000000 2. Imei number : 000000000000000 Backup nvram file. Succesfuly Save path : C:\Program Files (x86)\Tr Tools PRO\Backup\Mtk\Calibration\Flash Mode\Redmi Note 11S 4G-POCO M4 Pro 4G (miel)-2022-12-17-14-44-05.tr First imei repair. Succesfuly Second imei repair. Succesfuly Reboot to normal. Succesfuly Process status : Successful Process time : 129 .s Process number : 3825738 |
12-17-2022, 14:03 | #51 (permalink) |
Member: 52362 Status: Offline Thanks Meter: 35 | oppo ax5s cph1920 imei repair success Verifying user information. Successful Program version : 1.0.5.2 Process name : Mtk Imei Repair (Adb and Flash Methot) Process model name : Oppo AX5S (CPH1920) Waiting adb connection. Found. Port Information : Name : Android Composite ADB Interface Path : \\.\usb#vid_22d9&pid_2765&mi_01#7&1b1de73a&0&0001# {f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} Open adb path. Succesfuly Check adb connection. Succesfuly Reading device information. Succesfuly Brand name : OPPO Model name : CPH1920 Release : 8.1.0 Security version : 2020-10-05 Display id : CPH1920EX_11_A.25_00000000 Date : 1603249714 Description : full_oppo6765_18510-user 8.1.0 O11019 1603249719 release-keys Cpu version : arm64-v8a Locale : en-US Id : O11019 Serial number : NZ6H4TLR5HB6YLSO Security partition : nvram,nvdata Frp partition : /dev/block/platform/bootdevice/by-name/frp Build version : 1603249978 LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port_V1632 Number : 19 Path : \\.\usb#vid_0e8d&pid_0003#6&1acfd2d8&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6765 (Helio P35/G35) Hardware code : 0x00000766 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Passive DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : FE28B25364B4099F5B5C86698BEAF3E0 Get socid. Succesfuly Meid : 9708594B957D18FCE18AAD4CB424CEB02EA408F912A598F647 9313FD6C231958 Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_oppo6765_18510.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 232 KB (0x0000000000200000) DRAM size : 232 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : eMMC Disk size : 58,24 GB Disk cid : GP6BM Check storage life. Succesfuly Reading device partition. Succesfuly Part count : 40 Download protocol start. Succesfuly Backup nvram file. Succesfuly Backup count : 3 Path : C:\Program Files (x86)\Tr Tools PRO\Backup\Mtk\Calibration\Flash Mode\AX5S (CPH1920)-2022-12-17-19-59-11.tr Clear calibration data. Succesfuly Download protocol finish. Succesfuly Reboot device. Succesfuly Waiting adb connection. Found. Port Information : Name : Android Composite ADB Interface Path : \\.\usb#vid_22d9&pid_2765&mi_01#7&1b1de73a&0&0001# {f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} The device is expected to be ready. Succesfuly LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port_V1632 Number : 19 Path : \\.\usb#vid_0e8d&pid_0003#6&1acfd2d8&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6765 (Helio P35/G35) Hardware code : 0x00000766 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Passive DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : FE28B25364B4099F5B5C86698BEAF3E0 Get socid. Succesfuly Meid : 9708594B957D18FCE18AAD4CB424CEB02EA408F912A598F647 9313FD6C231958 Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_oppo6765_18510.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 232 KB (0x0000000000200000) DRAM size : 232 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : eMMC Disk size : 58,24 GB Disk cid : GP6BM Check storage life. Succesfuly Reading device partition. Succesfuly Part count : 40 Download protocol start. Succesfuly Fast methot init. Succesfuly First imei calculation from server. Succesfuly Second imei calculation from server. Succesfuly The calculated file is written to the device. Succesfuly Patch cert. Succesfuly Download protocol finish. Succesfuly Reboot device. Succesfuly Process status : Successful Process time : 248 .s Process number : 3835049 |
12-18-2022, 08:52 | #52 (permalink) |
Member: 52362 Status: Offline Thanks Meter: 35 | Redmi Note 8 Begonia imei repair success Verifying user information. Successful Program version : 1.0.5.2 Process name : Mtk Imei Repair (Flash Mode (Dual Sim)) Process model name : Xiaomi Redmi Note 8 Pro (begonia) LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port_V1632 Number : 19 Path : \\.\usb#vid_0e8d&pid_0003#6&1acfd2d8&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6785 (Helio G90) Hardware code : 0x00000813 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Active DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : E9135045A6C7F5FCDB29666C5A6D020C Get socid. Succesfuly Meid : D29E36DF03B2F6CE9DE5E0F15BBD4357C85B56049A5E3EDEAA A7A52ACFD6F4DE Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_begonia.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 512 KB (0x0000000000200000) DRAM size : 512 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : uFS Disk size : 119,17 GB Disk cid : KM2V8001CM-B70 Check storage life. Succesfuly Reading device partition. Succesfuly Part count : 47 Download protocol start. Succesfuly Reading device information. Succesfuly Brand name : Redmi Model name : Redmi Note 8 Pro Release : 10 Security version : 2021-04-01 Display id : QP1A.190711.020 Date : 1620929277 Description : begonia-user 10 QP1A.190711.020 V12.0.8.0.QGGMIXM release-keys Cpu version : arm64-v8a Locale : en-GB Id : QP1A.190711.020 Backup nvram file. Succesfuly Backup count : 8 Path : C:\Program Files (x86)\Tr Tools PRO\Backup\Mtk\Calibration\Flash Mode\Redmi Note 8 Pro (begonia)-2022-12-18-14-25-07.tr Reading imei number. Succesfuly 1. Imei number : 868368046722460 2. Imei number : 868368049222468 Fast methot init. Succesfuly First imei calculation from server. Succesfuly Second imei calculation from server. Succesfuly The calculated file is written to the device. Succesfuly Backup cert. Succesfuly Patch cert. Succesfuly Patch vbmeta : Succesfuly Device bootloader encryption is calculated from server. Succesfuly Download protocol finish. Succesfuly Reboot device. Succesfuly Process status : Successful Process time : 141 .s Process number : 3844914 |
The Following User Says Thank You to GSM_STARCOM For This Useful Post: |
12-25-2022, 09:26 | #53 (permalink) |
Member: 52362 Status: Offline Thanks Meter: 35 | Redmi Note 8 Ginkgo imei repair success Verifying user information. Successful Program version : 1.0.5.2 Process name : Xiaomi Qualcomm Repair Process model name : Xiaomi Redmi Note 8 (ginkgo) Security reset protocol : Adb Mode (Fast) Waiting adb connection. Found. Port Information : Name : Android Composite ADB Interface Path : \\.\usb#vid_18d1&pid_4ee2&mi_01#7&cb84f2f&0&0001#{ f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} Open adb path. Succesfuly Check adb connection. Succesfuly Reading device information. Succesfuly Brand name : xiaomi Model name : Redmi Note 8 Release : 11 Security version : 2022-07-01 Display id : RKQ1.201004.002 test-keys Date : 1657795931 Description : ginkgo-user 11 RKQ1.201004.002 V12.5.3.0.RCOIDXM release-keys 1. Imei number : 866836042473330 Cpu version : arm64-v8a Locale : ID Id : RKQ1.201004.002 Product name : M1908C3JE Serial number : 1d886a59 Security partition : modemst1,modemst2,fsg Frp partition : /dev/block/bootdevice/by-name/frp Build version : V12.5.3.0.RCOIDXM Bootloader lockstate : unlocked Get root version. Succesfuly No root permissions. Reboot to bootloader. Succesfuly Wait usb reset. Succesfuly Waiting fastboot mode. Found. Port Information : Name : Android Sooner Single ADB Interface Path : \\.\usb#vid_18d1&pid_d00d#1d886a59#{f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} Open usb. Succesfuly Reading device information. Succesfuly Product name : ginkgo Token key : VQEBIAEQOueVHhCWFIGHdqTfExC9pwMGZ2lua2dvAgTKXaSP Serial number : 1d886a59 Bootloader lock status : Unlocked Kernel name : uefi File is being verified. Succesfuly Rooting device. Succesfuly Reboot device. Succesfuly Wait usb reset. Succesfuly Waiting adb connection. Found. The device is expected to be ready. Succesfuly Waiting adb connection. Found. Open adb path. Succesfuly Checking root permission. Succesfuly Get root version. Succesfuly Root version : 1.5:MAGISKSU(TRTOOLSPRO) Backup cert. Succesfuly Save path : C:\Program Files (x86)\Tr Tools PRO\Backup\Cert\Xiaomi-Redmi Note 8 (ginkgo)-2022-12-25-15-19-55.tr Waiting adb connection. Found. Open adb path. Succesfuly Check adb connection. Succesfuly Reboot to bootloader. Succesfuly Wait usb reset. Succesfuly Waiting fastboot mode. Found. Port Information : Name : Android Sooner Single ADB Interface Path : \\.\usb#vid_18d1&pid_d00d#1d886a59#{f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} Open usb. Succesfuly Reading device information. Succesfuly Product name : ginkgo Token key : VQEBIAEQshv3lcIIzXSsPSWoDW8FAwMGZ2lua2dvAgTKXaSP Serial number : 1d886a59 Bootloader lock status : Unlocked Kernel name : uefi Check fastbootd. Succesfuly Check folder from server. Folder not found. Detecting partition. Succesfuly Clear security. Succesfuly Reboot device. Succesfuly Wait usb reset. Succesfuly Waiting adb connection. Found. The device is expected to be ready. Succesfuly Waiting adb connection. Found. Open adb path. Succesfuly Checking root permission. Succesfuly Diag port opening. Succesfuly 5 Waiting second. Succesfuly Waiting diag port. Succesfuly Port Information : Number : COM90 Connect diag port. Succesfuly Reading device information. Succesfuly Diag build version : 0X4256 0X4115 [MPSS.AT.4.3.1-00270-NICOBAR_GEN_PACK-1.433714.1.435199.1] Diag version : [NICOBAR.] [JUN 27 2022] [23:37:24SEP] 1. Imei number : 000000000000000 2. Imei number : 000000000000000 Repair second imei. Succesfuly Enable multi sim. Succesfuly Connect diag port. Succesfuly Enable multi sim. Succesfuly Connect diag port. Succesfuly Send spc code. Succesfuly Reading list from server. Succesfuly File is approved from the server. Succesfuly Downloading file. Succesfuly Restore calibration data. Succesfuly Waiting adb connection. Found. Open adb path. Succesfuly Check adb connection. Succesfuly Reboot to normal. Succesfuly Wait usb reset. Succesfuly Process status : Successful Process time : 411 .s Process number : 3974130 |
12-28-2022, 07:28 | #54 (permalink) |
Member: 52362 Status: Offline Thanks Meter: 35 | Redmi 9C angelica imei repair success Verifying user information. Successful Program version : 1.0.5.2 Process name : Mtk Imei Repair (Flash Mode (Dual Sim)) Process model name : Xiaomi Redmi 9C (angelica) LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port_V1632 Number : 19 Path : \\.\usb#vid_0e8d&pid_0003#6&1acfd2d8&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6765 (Helio P35/G35) Hardware code : 0x00000766 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Active DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : 39C57BEE54191BCA6F2290F40C7F4B88 Get socid. Succesfuly Meid : 6788BCCF198E9817A0412B413FAF93A1D7B1525D207C76FA0E B05A6BF736AC70 Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Reading list from server. Succesfuly File is approved from the server. Succesfuly Downloading file. Succesfuly File is being verified. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_k62v1_64_bsp.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 232 KB (0x0000000000200000) DRAM size : 232 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : eMMC Disk size : 58,24 GB Disk cid : Y2P06 Check storage life. Succesfuly Reading device partition. Succesfuly Part count : 43 Download protocol start. Succesfuly Reading device information. Succesfuly Brand name : Redmi Model name : M2006C3MG Release : 10 Security version : 2022-06-01 Display id : QP1A.190711.020 Date : 1655116257 Description : angelica-user 10 QP1A.190711.020 V12.0.22.0.QCRMIXM release-keys Locale : en-GB Id : QP1A.190711.020 Backup nvram file. Succesfuly Backup count : 7 Path : C:\Program Files (x86)\Tr Tools PRO\Backup\Mtk\Calibration\Flash Mode\Redmi 9C (angelica)-2022-12-28-13-22-42.tr Reading imei number. Succesfuly 1. Imei number : 869812058829647 2. Imei number : 869812058829654 Fast methot init. Succesfuly First imei calculation from server. Succesfuly Second imei calculation from server. Succesfuly The calculated file is written to the device. Succesfuly Backup cert. Succesfuly Patch cert. Succesfuly Patch vbmeta : Succesfuly Device bootloader encryption is calculated from server. Succesfuly Download protocol finish. Succesfuly Reboot device. Succesfuly Process status : Successful Process time : 360 .s Process number : 4023890 |
12-28-2022, 19:50 | #55 (permalink) |
Member: 52362 Status: Offline Thanks Meter: 35 | Redmi 7A pine imei repair success Verifying user information. Successful Program version : 1.0.5.2 Process name : Qualcomm Edl Imei Repair Process model name : Xiaomi Redmi 7A (pine) Waiting edl mode. Found. Port Information : Name : Qualcomm HS-USB QDLoader 9008 Path : \\.\usb#vid_05c6&pid_9008#6&1acfd2d8&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Open comport. Succesfuly Reading cpu information. Succesfuly Cpu name : Qualcomm Snapdragon 439 (SDM439) [000BF0E1] Loader mode : Auto Reading list from server. Succesfuly File is approved from the server. Succesfuly Downloading file. Succesfuly File is being verified. Succesfuly Loader writing. Succesfuly Set firehose protocol. Auth need. Calculating auth key. Succesfuly Sending auth key. Succesfuly Set try firehose protocol. Succesfuly Storage info reading. Succesfully Product name : HB8AP> Total size : 29,12 GB Block size : 512 Page size : 512 Physical number : 3 Manufacturer id : 144 Serial number : 2932911149 Firmware version : 875573296 Memory type : EMMC Reading device information. Succesfuly Brand name : Xiaomi Model name : Redmi 7A Release : 9 Security version : 2019-07-01 Display id : ZQL1533-pine-build-20190801153933 Date : 1564648923 Description : pine-user 9 PKQ1.190319.001 V10.2.5.0.PCMEUXM release-keys Locale : en-GB Id : PKQ1.190319.001 Clear security. Succesfuly Reboot device. Succesfuly Waiting diag port. Succesfuly Port Information : Number : COM55 Connect diag port. Succesfuly Reading device information. Succesfuly Diag build version : 0X3056 0X4108 [MPSS.JO.3.2-00196-SDM439_GENNS_PACK-2.205439.1.212775.2] Diag version : [SDM439.G] [JUL 30 2019] [18:01:26JUL] 1. Imei number : 000000000000000 2. Imei number : 000000000000000 Repair second imei. Succesfuly Enable multi sim. Succesfuly Connect diag port. Succesfuly Enable multi sim. Succesfuly Connect diag port. Succesfuly Send spc code. Succesfuly Reading list from server. Succesfuly File is approved from the server. Succesfuly Downloading file. Succesfuly Restore calibration data. Succesfuly Diag closed. Succesfuly Process status : Successful Process time : 604 .s |
01-05-2023, 13:38 | #56 (permalink) |
Product Supporter Join Date: Jul 2015 Location: pk
Member: 2436842 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,937 | Tecno Spark 4 MTK6261 Flashing Done By TR Tool Pro Tecno Spark 4 MTK6261 Flashing Done By TR Tool Pro Code: Verifying user information. Successful Program version : 1.0.5.2 Process name : Mtk Firmware Write Process model name : Tecno Spark 4 Lite LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port_V1632 Number : 6 Path : \\.\usb#vid_0e8d&pid_0003#5&31036e8e&0&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6761/MT6762/MT3369/MT8766B (Helio A20/P22/A22/A25/G25) Hardware code : 0x00000717 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0200 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Passive DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : C98E12934944D3091FB027084C84272B Get socid. Succesfuly Meid : 1402D7C5F2024342D6D738EB58604C6348EEC4CC411E1938F5484D7087B66A3B Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_kc2_h6113.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 233 KB (0x0000000000200000) DRAM size : 233 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : eMMC Disk size : 29.12 GB Disk cid : GD6BM Check storage life. Succesfuly Reading device partition. Succesfuly Part count : 39 Download protocol start. Succesfuly preloader (230.64 KB) . md1img (49.28 MB) . spmfw (47.53 KB) . scp1 (526.45 KB) . scp2 (526.45 KB) . sspm_1 (423.25 KB) . sspm_2 (423.25 KB) . lk (689.59 KB) . lk2 (689.59 KB) . boot (32 MB) . logo (1.4 MB) . dtbo (8 MB) . tee1 (2.15 MB) . tee2 (2.15 MB) . vendor (358.52 MB) . system (3.1 GB) . vbmeta (4 KB) . cache (144.17 KB) . recovery (32 MB) . tkv (1024 KB) . tranfs (144.17 KB) . userdata (236.29 KB) . Download protocol finish. Succesfuly Reboot device. Succesfuly Process status : Successful Process time : 159 .s Process number : 4167886 Br FactoryFilePak |
05-23-2023, 01:28 | #59 (permalink) | |
Junior Member Join Date: May 2021 Location: turkey Age: 29
Member: 2989454 Status: Offline Thanks Meter: 3 | Huawei Honor 50 (NTH-NX9) Frp Reset Quote:
05-23-2023, 01:30 | #60 (permalink) | |
Member: 2989454 Status: Offline Thanks Meter: 3 | Nothing Phone 1 One Click IMEI Repair Success ! Quote:
