Go Back   GSM-Forum > Product Support Sections > IMEI or online Server Products > Tr Team
Old 04-23-2022, 15:03   #1 (permalink)
Crazy Poster
Member: 3008540
Thanks Meter: 13
Realme c25 rmx31191 restart on logo after repair.
Verifying user information. Successful
Program version : 1.0.3.8
Process name : Mtk Imei Repair (Adb and Flash Methot) (PERMANENT IMEI !!!)
Process model name : Realme Realme C25 (RMX3191)
Waiting adb connection. Found.
Port Information :
Path : \\.\usb#vid_22d9&pid_2769#vwpvovijqwvgqoqo#{f72fe0 d4-cbcb-407d-8814-9ed673d0dd6b}
Open adb path. Succesfuly
Check adb connection. Succesfuly
Reading device information. Succesfuly
Brand name : realme
Model name : RMX3191
Release : 11
Security version : 2022-03-05
Display id : RMX3191_11_A.27_220318
Date : 1647614801
Description : sys_oplus_mssi_64_cn-user 11 RP1A.200720.011 1614161234317 release-keys
Cpu version : arm64-v8a
Locale : en-US
Serial number : VWPVOVIJQWVGQOQO
Security partition : nvram,nvdata
Frp partition : /dev/block/platform/bootdevice/by-name/frp
LibUsb checking and installing. Succesfuly
Preloader mode: Turn off the device and plug in a usb cable.
Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button.
Waiting preloader or brom port. Found.
Port Information :
Name : USB Serial Device
Number : 56
Path : \\.\usb#vid_0e8d&pid_0003#6&284a7c69&0&3#{86e0d1e0-8089-11d0-9ce4-08003e301f73}
Connection Mode : Brom
Connect mtk port. Succesfuly
Connecting brom mode. Succesfuly
Reading cpu information. Succesfuly
Cpu name : MT6768 (Helio P65/G85 k68v1)
Hardware code : 0x00000707
Hardware sub code : 0x8A00
Hardware version : 0xCA00
Sw version : 0x0000
Disabling watchdog. Succesfuly
Get config target. Succesfuly
SBC status : Active
SLA status : Passive
DAA status : Active
SWJTAG status : Active
EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive
Root cert required : Passive
Memory read auth : Active
Memory write auth : Active
Cmd 0xC8 blocked : Active
Get meid. Succesfuly
Meid : 0D2D7E19731C47F1E93F9C010FC4A3C8
Get socid. Succesfuly
Meid : F229AD30C30704AD17345B26C96D8280FE51CDCC6FDC3EF9E7 D0F51F16FDA5AD
Security bypass methot : Kamakiri2
Bypass security. Succesfuly
Reading emi from device. Succesfuly
Loading preloader file. Succesfuly
Emi name : preloader_oppo6768.bin
Emi version : V116
Searching da from server. Succesfuly
Da load mode : Stream
File is being verified. Succesfuly
Loading da file. Succesfuly
Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394
Da identifier : MTK_DOWNLOAD_AGENT
Search entry. Succesfuly
Flash protocol : XFlash
Sending boot. Succesfuly
Jump first boot. Succesfuly
Set flash mode device. Succesfuly
Get flash mode. Succesfuly
Flash mode : brom
Get ram information. Succesfuly
SRAM size : 448 KB (0x0000000000200000)
DRAM size : 448 KB (0x0000000000200000)
Get storage information. Succesfuly
Send emi data. Succesfuly
Send second boot. Succesfuly
Storage type : eMMC
Disk size : 116.48 GB
Disk cid : NG1J9S
Check storage life. Succesfuly
Reading device partition. Succesfuly
Part count : 46
Download protocol start. Succesfuly
Backup nvram file. Succesfuly
Backup count : 3
Path : C:\Program Files (x86)\Tr Tools PRO\Backup\Mtk\Calibration\Flash Mode\Realme C25 (RMX3191)-2022-04-22-13-08-37.tr
Clear calibration data. Succesfuly
Download protocol finish. Succesfuly
Reboot device. Succesfuly
Port Information :
The device is expected to be ready. Succesfuly
Port Information :
Number : 56
Sw version : 0x0000
SBC status : Active
DAA status : Active
Emi version : V116
Flash mode : brom
Storage type : eMMC
Disk cid : NG1J9S
Part count : 46
Fast methot init. Succesfuly
First imei calculation from server. Succesfuly
Second imei calculation from server. Succesfuly
The calculated file is written to the device. Succesfuly
Patch cert. Succesfuly
Process status : Successful
Process time : 236 .s
Process number : 558527
how to solve this problem
The Following User Says Thank You to shahidm2 For This Useful Post:
Old 04-26-2022, 12:14   #2 (permalink)
Member: 1590400
hello Realme c25 rmx31191 software is needed non unlock
Old 04-26-2022, 12:40   #3 (permalink)
Crazy Poster
Member: 3008540
Thanks Meter: 13
u mean Realme c25 rmx31191firmware?
Old 05-06-2022, 09:45   #4 (permalink)
Member: 1590400
need software not sim lock
yes i want this
Old 05-06-2022, 09:53   #5 (permalink)
Crazy Poster
Member: 3008540
Thanks Meter: 13
Download
https://romprovider.com/download-realme-c25-flash-file/
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.14565 seconds with 7 queries
