06-02-2022, 11:25 | #1 (permalink) |
Freak Poster Join Date: Oct 2016 Location: india
Member: 2636476 Status: Offline Thanks Meter: 61 | realme narzo 30 pro rmx2117 imei repair success but still imei not show means not repair Code: Verifying user information. Successful Program version : 1.0.4.3 Process name : Mtk Imei Repair (Adb and Flash Methot) Process model name : Realme 7 5G (RMX2117) Waiting adb connection. Found. Port Information : Name : Android ADB Interface Path : \\.\usb#vid_0e8d&pid_201c#5&37870303&0&2#{f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} Open adb path. Succesfuly Check adb connection. Succesfuly Reading device information. Succesfuly Brand name : realme Model name : RMX2117 Release : 11 Security version : 2021-07-05 Display id : RMX2117_11_C.03_210723 Date : 1627050205 Description : sys_oplus_mssi_64_cn-user 11 RP1A.200720.011 1615837624098 release-keys Cpu version : arm64-v8a Locale : en-US Id : RP1A.200720.011 Serial number : FAX4ONBQOBPFIFXO Security partition : nvram,nvdata Frp partition : /dev/block/by-name/frp LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port Number : 692 Path : \\.\usb#vid_0e8d&pid_0003#5&37870303&0&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6853 (Dimensity 720 5G) Hardware code : 0x00000996 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Passive DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : 99A24F2F348F2351DBDC3958320B59DD Get socid. Succesfuly Meid : 377281A1DBF78C42E14F943151D08DD50115849799F7A87345E20994FA468050 Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_oppo6853.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 448 KB (0x0000000000200000) DRAM size : 448 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : uFS Disk size : 59.59 GB Disk cid : H9HQ53AECMMDAR Check storage life. Succesfuly Reading device partition. Succesfuly Part count : 60 Download protocol start. Succesfuly Clear calibration data. Succesfuly Download protocol finish. Succesfuly Reboot device. Succesfuly Waiting adb connection. Found. Port Information : Name : Android ADB Interface Path : \\.\usb#vid_0e8d&pid_201c#5&37870303&0&2#{f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} The device is expected to be ready. Succesfuly LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port Number : 692 Path : \\.\usb#vid_0e8d&pid_0003#5&37870303&0&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6853 (Dimensity 720 5G) Hardware code : 0x00000996 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Passive DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : 99A24F2F348F2351DBDC3958320B59DD Get socid. Succesfuly Meid : 377281A1DBF78C42E14F943151D08DD50115849799F7A87345E20994FA468050 Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_oppo6853.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 448 KB (0x0000000000200000) DRAM size : 448 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : uFS Disk size : 59.59 GB Disk cid : H9HQ53AECMMDAR Check storage life. Succesfuly Reading device partition. Succesfuly Part count : 60 Download protocol start. Succesfuly Fast methot init. Succesfuly First imei calculation from server. Succesfuly Second imei calculation from server. Succesfuly The calculated file is written to the device. Succesfuly Patch cert. Succesfuly Download protocol finish. Succesfuly Reboot device. Succesfuly Process status : Successful Process time : 146 .s Process number : 907745 |
06-04-2022, 10:25 | #4 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Narowal
Member: 207708 Status: Offline Sonork: 100.1602241 Thanks Meter: 1,005 | To SIR ::SeCi:: I have the same issue with Redmi 10X 5G repair success but still imei not change But with Sim Both Signal are ok. May backgroung imei Change ok ? is it possible ? Last edited by umarnlw; 06-04-2022 at 10:30. |
