06-14-2022, 16:24 | #1 (permalink) |
Freak Poster Join Date: Oct 2016 Location: india
Member: 2636476 Status: Offline Thanks Meter: 61 | redmi 6a imei not repair log show success Code: Verifying user information. Successful Program version : 1.0.4.3 Process name : Mtk Imei Repair (Meta and Flash Methot) Process model name : Xiaomi Redmi 6A (cactus) Load from library. Succesfuly Setting up the library. Succesfuly LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port Number : 3 Path : \\.\usb#vid_0e8d&pid_0003#6&111d0584&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6765 (Helio P35/G35) Hardware code : 0x00000766 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Active DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : 7F8ED2641CCD7CF69CB4BF96E31BADBB Get socid. Succesfuly Meid : 21B2BFFC6DF0AACAA19F8B298C87E4B576B770972A2C3D3777E1614D81719DD9 Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_cactus.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly |
