05-04-2022, 19:14 | #1 (permalink) |
Banned Join Date: May 2013 Location: Hacked by Hackflax on tiktok
Member: 1941705 Status: Offline Thanks Meter: 1,248 | Redmi note 10 5G Bootloader Unlock Tr Tools Pro Verifying user information. Successful Program version : 1.0.4.0 Process name : Mtk Flash Mode Toolkit (Bootloader Unlock) Process model name : Xiaomi Redmi Note 10 5G-Redmi Note 10T 5G-POCO M3 Pro 5G (camellia) LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port Number : 28 Path : \\.\usb#vid_0e8d&pid_0003#6&260a8e58&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6833 (Dimensity 700 5G k6833) Hardware code : 0x00000989 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Active DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : E96125DE2BF547D16E3F2DF0A3932FD4 Get socid. Succesfuly Meid : AED923BB00D0FC39F8D12BE3962F95D2B20841B460E04EA045 0DE82088B3300F Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_camellia.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 448 KB (0x0000000000200000) DRAM size : 448 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : uFS Disk size : 119,17 GB Disk cid : MT128GASAO4U21 Check storage life. Succesfuly Reading device partition. Succesfuly Part count : 60 Download protocol start. Succesfuly Reading device information. Succesfuly Brand name : Redmi Model name : M2103K19C Release : 12 Security version : 2022-03-01 Display id : AN3516-camellia-build-20220317192219 Date : 1647516389 Description : camellia-user 12 SP1A.210812.016 V13.0.4.0.SKSCNXM release-keys Cpu version : arm64-v8a Locale : zh-CN Id : SP1A.210812.016 Device bootloader encryption is calculated from server. Succesfuly Download protocol finish. Succesfuly Reboot device. Succesfuly Process status : Successful Process time : 113 .s Process number : 630214 |
The Following User Says Thank You to Xaker2012 For This Useful Post: |
