04-23-2022, 15:03 | #1 (permalink) |
Freak Poster Join Date: Mar 2022 Location: fsd Age: 23
Member: 3008540 Status: Offline Thanks Meter: 17 | Realme c25 rmx31191 restart on logo after repair. Verifying user information. Successful Program version : 1.0.3.8 Process name : Mtk Imei Repair (Adb and Flash Methot) (PERMANENT IMEI !!!) Process model name : Realme Realme C25 (RMX3191) Waiting adb connection. Found. Port Information : Name : WinUsb Device Path : \\.\usb#vid_22d9&pid_2769#vwpvovijqwvgqoqo#{f72fe0 d4-cbcb-407d-8814-9ed673d0dd6b} Open adb path. Succesfuly Check adb connection. Succesfuly Reading device information. Succesfuly Brand name : realme Model name : RMX3191 Release : 11 Security version : 2022-03-05 Display id : RMX3191_11_A.27_220318 Date : 1647614801 Description : sys_oplus_mssi_64_cn-user 11 RP1A.200720.011 1614161234317 release-keys Cpu version : arm64-v8a Locale : en-US Id : RP1A.200720.011 Serial number : VWPVOVIJQWVGQOQO Security partition : nvram,nvdata Frp partition : /dev/block/platform/bootdevice/by-name/frp LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : USB Serial Device Number : 56 Path : \\.\usb#vid_0e8d&pid_0003#6&284a7c69&0&3#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6768 (Helio P65/G85 k68v1) Hardware code : 0x00000707 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Passive DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : 0D2D7E19731C47F1E93F9C010FC4A3C8 Get socid. Succesfuly Meid : F229AD30C30704AD17345B26C96D8280FE51CDCC6FDC3EF9E7 D0F51F16FDA5AD Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_oppo6768.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 448 KB (0x0000000000200000) DRAM size : 448 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : eMMC Disk size : 116.48 GB Disk cid : NG1J9S Check storage life. Succesfuly Reading device partition. Succesfuly Part count : 46 Download protocol start. Succesfuly Backup nvram file. Succesfuly Backup count : 3 Path : C:\Program Files (x86)\Tr Tools PRO\Backup\Mtk\Calibration\Flash Mode\Realme C25 (RMX3191)-2022-04-22-13-08-37.tr Clear calibration data. Succesfuly Download protocol finish. Succesfuly Reboot device. Succesfuly Waiting adb connection. Found. Port Information : Name : WinUsb Device Path : \\.\usb#vid_22d9&pid_2769#vwpvovijqwvgqoqo#{f72fe0 d4-cbcb-407d-8814-9ed673d0dd6b} The device is expected to be ready. Succesfuly LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : USB Serial Device Number : 56 Path : \\.\usb#vid_0e8d&pid_0003#6&284a7c69&0&3#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6768 (Helio P65/G85 k68v1) Hardware code : 0x00000707 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Passive DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : 0D2D7E19731C47F1E93F9C010FC4A3C8 Get socid. Succesfuly Meid : F229AD30C30704AD17345B26C96D8280FE51CDCC6FDC3EF9E7 D0F51F16FDA5AD Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_oppo6768.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 448 KB (0x0000000000200000) DRAM size : 448 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : eMMC Disk size : 116.48 GB Disk cid : NG1J9S Check storage life. Succesfuly Reading device partition. Succesfuly Part count : 46 Download protocol start. Succesfuly Fast methot init. Succesfuly First imei calculation from server. Succesfuly Second imei calculation from server. Succesfuly The calculated file is written to the device. Succesfuly Patch cert. Succesfuly Download protocol finish. Succesfuly Reboot device. Succesfuly Process status : Successful Process time : 236 .s Process number : 558527 how to solve this problem |
The Following User Says Thank You to shahidm2 For This Useful Post: |
