Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > TR TOOLS PRO
Old 05-04-2022, 19:14   #1 (permalink)
Member: 1941705
Thanks Meter: 1,248
Redmi note 10 5G Bootloader Unlock Tr Tools Pro
Verifying user information. Successful
Program version : 1.0.4.0
Process name : Mtk Flash Mode Toolkit (Bootloader Unlock)
Process model name : Xiaomi Redmi Note 10 5G-Redmi Note 10T 5G-POCO M3 Pro 5G (camellia)
LibUsb checking and installing. Succesfuly
Preloader mode: Turn off the device and plug in a usb cable.
Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button.
Waiting preloader or brom port. Found.
Port Information :
Name : MediaTek USB Port
Number : 28
Path : \\.\usb#vid_0e8d&pid_0003#6&260a8e58&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73}
Connection Mode : Brom
Connect mtk port. Succesfuly
Connecting brom mode. Succesfuly
Reading cpu information. Succesfuly
Cpu name : MT6833 (Dimensity 700 5G k6833)
Hardware code : 0x00000989
Hardware sub code : 0x8A00
Hardware version : 0xCA00
Sw version : 0x0000
Disabling watchdog. Succesfuly
Get config target. Succesfuly
SBC status : Active
SLA status : Active
DAA status : Active
SWJTAG status : Active
EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive
Root cert required : Passive
Memory read auth : Active
Memory write auth : Active
Cmd 0xC8 blocked : Active
Get meid. Succesfuly
Meid : E96125DE2BF547D16E3F2DF0A3932FD4
Get socid. Succesfuly
Meid : AED923BB00D0FC39F8D12BE3962F95D2B20841B460E04EA045 0DE82088B3300F
Security bypass methot : Kamakiri2
Bypass security. Succesfuly
Reading emi from device. Succesfuly
Loading preloader file. Succesfuly
Emi name : preloader_camellia.bin
Emi version : V116
Searching da from server. Succesfuly
Da load mode : Stream
File is being verified. Succesfuly
Loading da file. Succesfuly
Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394
Da identifier : MTK_DOWNLOAD_AGENT
Search entry. Succesfuly
Flash protocol : XFlash
Sending boot. Succesfuly
Jump first boot. Succesfuly
Set flash mode device. Succesfuly
Get flash mode. Succesfuly
Flash mode : brom
Get ram information. Succesfuly
SRAM size : 448 KB (0x0000000000200000)
DRAM size : 448 KB (0x0000000000200000)
Get storage information. Succesfuly
Send emi data. Succesfuly
Send second boot. Succesfuly
Storage type : uFS
Disk size : 119,17 GB
Disk cid : MT128GASAO4U21
Check storage life. Succesfuly
Reading device partition. Succesfuly
Part count : 60
Download protocol start. Succesfuly
Reading device information. Succesfuly
Brand name : Redmi
Model name : M2103K19C
Release : 12
Security version : 2022-03-01
Display id : AN3516-camellia-build-20220317192219
Date : 1647516389
Description : camellia-user 12 SP1A.210812.016 V13.0.4.0.SKSCNXM release-keys
Cpu version : arm64-v8a
Locale : zh-CN
Device bootloader encryption is calculated from server. Succesfuly
Download protocol finish. Succesfuly
Reboot device. Succesfuly
Process status : Successful
Process time : 113 .s
Process number : 630214
The Following User Says Thank You to Xaker2012 For This Useful Post:
Page generated in 0.13546 seconds with 8 queries
