04-19-2022, 14:12 | #1 (permalink) |
No Life Poster Join Date: May 2015 Location: mumbai Age: 27
Member: 2401939 Status: Offline Thanks Meter: 682 | rmx1825 imei repair error fix tr pro tool Program version : 1.0.3.8 Process name : Mtk Imei Repair (Adb and Flash Methot) (PERMANENT IMEI !!!) Process model name : Realme Realme 3 (RMX1825) Waiting adb connection. Found. Port Information : Name : Android ADB Interface Path : \\.\usb#vid_22d9&pid_2769#ukx8jvxgpn7pjz85#{f72fe0 d4-cbcb-407d-8814-9ed673d0dd6b} Open adb path. Succesfuly Check adb connection. Succesfuly Reading device information. Succesfuly Brand name : Realme Model name : RMX1827 Release : 10 Security version : 2021-05-05 Display id : RMX1827_11_C.21_2e3b1ada Date : 1621591205 Description : full_oppo6771-user 10 QP1A.190711.020 08805472cb0b87b3 release-keys Cpu version : arm64-v8a Locale : en-US Id : QP1A.190711.020 Serial number : UKX8JVXGPN7PJZ85 Security partition : nvram,nvdata Frp partition : /dev/block/platform/bootdevice/by-name/frp LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port_V1632 Number : 6 Path : \\.\usb#vid_0e8d&pid_0003#5&2108ad5d&0&13#{86e0d1e 0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6771/MT8385/MT8183/MT8666 (Helio P60/P70/G80) Hardware code : 0x00000788 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Passive DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : 4DF63B1D01661BA9FF61A210821485E4 Get socid. Succesfuly Meid : 5C08A00B1B9E52A6612D40496D193B8C5C11AF888FAF5497B2 D43AD56CAD37B6 Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_oppo6771.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 228 KB (0x0000000000200000) DRAM size : 228 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : eMMC Disk size : 58.24 GB Disk cid : JHCG8a Check storage life. Succesfuly Reading device partition. Succesfuly Part count : 44 Download protocol start. Succesfuly Backup nvram file. Succesfuly Backup count : 3 Path : C:\Program Files (x86)\Tr Tools PRO\Backup\Mtk\Calibration\Flash Mode\Realme 3 (RMX1825)-2022-04-19-18-34-21.tr Clear calibration data. Succesfuly Download protocol finish. Succesfuly Reboot device. Succesfuly Waiting adb connection. Found. Port Information : Name : Android ADB Interface Path : \\.\usb#vid_22d9&pid_2769#ukx8jvxgpn7pjz85#{f72fe0 d4-cbcb-407d-8814-9ed673d0dd6b} The device is expected to be ready. Succesfuly LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port_V1632 Number : 6 Path : \\.\usb#vid_0e8d&pid_0003#5&2108ad5d&0&13#{86e0d1e 0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6771/MT8385/MT8183/MT8666 (Helio P60/P70/G80) Hardware code : 0x00000788 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Passive DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : 4DF63B1D01661BA9FF61A210821485E4 Get socid. Succesfuly Meid : 5C08A00B1B9E52A6612D40496D193B8C5C11AF888FAF5497B2 D43AD56CAD37B6 Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_oppo6771.bin Emi version : V116 Searching da from server. Succesfuly File is approved from the server. Succesfuly Downloading file. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.2018-06-14.16:55_443441 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 256 KB (0x0000000000200000) DRAM size : 256 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : eMMC Disk size : 58.24 GB Disk cid : JHCG8a Check storage life. Error found. Error information and Solition suggestions Function name : StorLifeCheckXFlash Error number : -1 Solition : 1. Your transaction may be left unfinished. 2. The memory chip may be faulty. 3. Protocol may not be supported. Process status : Error Process time : 213 .s Process number : 543284 |
