Tekno Ke5 FRP Clear Done With TR Tool
Verifying user information. Successful
Program version : 1.0.3.9
Process name : Mtk Flash Mode Toolkit (Frp Reset)
Process model name : Tecno Spark 7 Pro (KF8)
LibUsb checking and installing. Succesfuly
Preloader mode: Turn off the device and plug in a usb cable.
Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button.
Waiting preloader or brom port. Found.
Port Information :
Name : MediaTek PreLoader USB VCOM (Android)
Number : 28
Path : \\.\usb#vid_0e8d&pid_2000#6&1553f441&0&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73}
Connection Mode : Preloader
Preloader switch brom mode. Succesfuly
Port Information :
Name : MediaTek USB Port
Number : 24
Path : \\.\usb#vid_0e8d&pid_0003#6&1553f441&0&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73}
Brom
Connect mtk port. Succesfuly
Connecting brom mode. Succesfuly
Reading cpu information. Succesfuly
Cpu name : MT6761/MT6762/MT3369/MT8766B (Helio A20/P22/A22/A25/G25)
Hardware code : 0x00000717
Hardware sub code : 0x8A00
Hardware version : 0xCA00
Sw version : 0x0200
Disabling watchdog. Succesfuly
Get config target. Succesfuly
SBC status : Active
SLA status : Passive
DAA status : Active
SWJTAG status : Active
EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive
Root cert required : Passive
Memory read auth : Active
Memory write auth : Active
Cmd 0xC8 blocked : Active
Get meid. Succesfuly
Meid : 04E2AC516B20D4AE22AA654BAF02E587
Get socid. Succesfuly
Meid : 3CE895FC94E45609DDF2025664E5F5627386A84793426EF01A 72996F8A1AD657
Security bypass methot : Kamakiri2
Bypass security. Succesfuly
Reading emi from device. Succesfuly
Loading preloader file. Succesfuly
Emi name : preloader_ke5_h6123go.bin
Emi version : V116
Searching da from server. Succesfuly
Da load mode : Stream
File is being verified. Succesfuly
Loading da file. Succesfuly
Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394
Da identifier : MTK_DOWNLOAD_AGENT
Search entry. Succesfuly
Flash protocol : XFlash
Sending boot. Succesfuly
Jump first boot. Succesfuly
Set flash mode device. Succesfuly
Get flash mode. Succesfuly
Flash mode : brom
Get ram information. Succesfuly
SRAM size : 233 KB (0x0000000000200000)
DRAM size : 233 KB (0x0000000000200000)
Get storage information. Succesfuly
Send emi data. Succesfuly
Send second boot. Succesfuly
Storage type : eMMC
Disk size : 29.12 GB
Disk cid : QX63A
Check storage life. Succesfuly
Reading device partition. Succesfuly
Part count : 41
Download protocol start. Succesfuly
Reading device information. Succesfuly
Brand name : TECNO
Model name : TECNO KE5
Release : 10
Security version : 2020-12-05
Display id : KE5-H6123ABC-QGo-GL-201216V215
Date : 1608115516
Description : full_ke5_h6123go-user 10 QP1A.190711.020 58960 release-keys
Locale : en-US
Frp clear. Succesfuly
Download protocol finish. Succesfuly
Reboot device. Succesfuly
Process status : Successful
Process time : 41 .s
Process number : 594235
