09-23-2022, 19:15 | #29 (permalink) |
Junior Member Join Date: Sep 2009 Location: Peru
Member: 1128985 Status: Offline Thanks Meter: 17 | ERROR NOTE 9S Verifying user information. Successful Program version : 1.0.5.1 Process name : Qualcomm Sideload Mode Toolkit (Bootloader Unlock (Temporary)) Process model name : Xiaomi Redmi Note 9 Pro-Redmi Note 9S (curtana) Waiting adb connection. Found. Port Information : Name : Android ADB Interface Path : \\.\usb#vid_18d1&pid_4e11#bb159f09#{f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} Open adb path. Succesfuly Check adb connection. Succesfuly Checking sideload mode. Succesfuly Reading device information. Succesfuly Model name : curtana_global Release : 10 Description : V12.0.3.0.QJWMIXM Language : en Serial number : 0x9bde848e Reading list from server. Succesfuly File is being verified. Succesfuly Reading security part... Succesfuly Device bootloader encryption is calculated from server. Error found. Error information and Solition suggestions Function name : BootFileTr Error number : -1 Solition : 1. Bootloader may be turned off. 2. The memory chip may be faulty. 3. The usb cable may be broken. (Connect the usb cable directly to the output of the motherboard.) Process status : Error Process time : 6 .s Process number : 2147608 |
09-27-2022, 06:37 | #30 (permalink) |
Insane Poster Join Date: Aug 2013 Location: Bishkek
Member: 2000965 Status: Offline Thanks Meter: 27 | Verifying user information. Successful Program version : 1.0.5.1 Process name : Qualcomm Sideload Mode Toolkit (Bootloader Unlock (Temporary)) Process model name : Xiaomi Redmi Note 9 Pro (joyeuse) Waiting adb connection. Found. Port Information : Name : Android ADB Interface Path : \\.\usb#vid_18d1&pid_4e11#6&38a36d0c&0&2#{f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} Open adb path. Succesfuly Check adb connection. Succesfuly Checking sideload mode. Succesfuly Reading device information. Succesfuly Model name : joyeuse_global Release : 10 Description : V12.0.3.0.QJZMIXM Language : ru Serial number : 0x596bbe4a Reading list from server. Succesfuly File is being verified. Succesfuly Reading security part... Succesfuly Device bootloader encryption is calculated from server. Error found. Error information and Solition suggestions Function name : BootFileTr Error number : -1 Solition : 1. Bootloader may be turned off. 2. The memory chip may be faulty. 3. The usb cable may be broken. (Connect the usb cable directly to the output of the motherboard.) Process status : Error Process time : 22 .s Process number : 2256009 |
