04-22-2022, 15:02 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Location: kocaeli Age: 46
Member: 58232 Status: Offline Thanks Meter: 91 | Xiaomi Redmi Note 9 merlin null done Verifying user information. Successful Program version : 1.0.3.8 Process name : Mtk Imei Repair (Adb and Flash Methot) (PERMANENT IMEI !!!) Process model name : Xiaomi Redmi Note 9-Redmi 10X 4G (merlin) Waiting adb connection. Found. Port Information : Name : Android ADB Interface Path : \\.\usb#vid_18d1&pid_4ee7#086365620407#{f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} Open adb path. Succesfuly Check adb connection. Succesfuly Reading device information. Succesfuly Brand name : Redmi Model name : M2003J15SC Release : 11 Security version : 2021-01-05 Display id : RP1A.200720.011 Date : 1648133103 Description : merlin-user 11 RP1A.200720.011 release-keys 1. Imei number : 864391044444758 Cpu version : arm64-v8a Locale : GB Id : RP1A.200720.011 Product name : M2003J15SI Serial number : 086365620407 Security partition : nvram,nvdata Frp partition : /dev/block/platform/bootdevice/by-name/frp LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port_V1632 Number : 124 Path : \\.\usb#vid_0e8d&pid_0003#7&14057a00&0&4#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6768 (Helio P65/G85 k68v1) Hardware code : 0x00000707 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Active DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : 788E828A7F102FC69992FDAA1C8AF538 Get socid. Succesfuly Meid : 4D7071034E1A8BAD8DA3FFEAAD3AE872507DD804B8C6ACA56D 94DE628700B8F4 Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Reading list from server. Succesfuly File is approved from the server. Succesfuly Downloading file. Succesfuly File is being verified. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_merlin.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 448 KB (0x0000000000200000) DRAM size : 448 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : eMMC Disk size : 116,48 GB Disk cid : NG1J9S Check storage life. Succesfuly Reading device partition. Succesfuly Part count : 47 Download protocol start. Succesfuly Backup nvram file. Succesfuly Backup count : 8 Path : C:\Program Files (x86)\Tr Tools PRO\Backup\Mtk\Calibration\Flash Mode\Redmi Note 9-Redmi 10X 4G (merlin)-2022-04-22-16-53-27.tr Clear calibration data. Succesfuly Download protocol finish. Succesfuly Reboot device. Succesfuly Waiting adb connection. Found. Port Information : Name : Android ADB Interface Path : \\.\usb#vid_18d1&pid_4ee7#086365620407#{f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} The device is expected to be ready. Succesfuly LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port_V1632 Number : 124 Path : \\.\usb#vid_0e8d&pid_0003#7&14057a00&0&4#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6768 (Helio P65/G85 k68v1) Hardware code : 0x00000707 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Active DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : 788E828A7F102FC69992FDAA1C8AF538 Get socid. Succesfuly Meid : 4D7071034E1A8BAD8DA3FFEAAD3AE872507DD804B8C6ACA56D 94DE628700B8F4 Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Reading list from server. Succesfuly File is approved from the server. Succesfuly Downloading file. Succesfuly File is being verified. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_merlin.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 448 KB (0x0000000000200000) DRAM size : 448 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : eMMC Disk size : 116,48 GB Disk cid : NG1J9S Check storage life. Succesfuly Reading device partition. Succesfuly Part count : 47 Download protocol start. Succesfuly Fast methot init. Succesfuly Second imei calculation from server. Succesfuly The calculated file is written to the device. Succesfuly Download protocol finish. Succesfuly Reboot device. Succesfuly Process status : Successful Process time : 134 .s Process number : 561574 |
The Following User Says Thank You to muzi_31 For This Useful Post: |
