01-27-2023, 07:08
#1 (permalink)
Join Date: Mar 2009 Location: YT - Channel RealFix-GRS.TV Age: 37
Member: 990711
Sonork: 100.1597405 Thanks Meter: 1,779 | Xiaomi Redmi 5 (can not find loader file!) AUTO DETECT INFO Quote:
Operation : Read Information
Phone Mode : EDL Mode
Selected Model : Xiaomi Redmi 5 [rosy]
- Please Disconnect battery and connect phone with test point
- Do not connect phone with connected battery
Waiting for QC EDL Mode port... OK
Port name : Qualcomm HS-USB QDLoader 9008 (COM23)
USB driver : qcusbser:2.1.3.7:05/29/2019
Manufacturer : Qualcomm Incorporated
Connecting to port [COM23]... OK
Trying to ReConnect with comport... OK
Reading chipset info... OK
Serial : 0x8da1d261
MSM_HW_ID : 0x0009a0e1 [SDM450]
OEM_ID : 0x0000 [Qualcomm]
MODEL_ID : 0x0000
OEM PK HASH : 0x57158eaf1814d78fd2b3105ece4db18a817a08ac664a5782 a925f3ff8403d39a
Checking loader db from server... OK
Downloading data from server... OK
Loading programmer... OK
Sending programmer to phone... OK
Configuration chip... OK Checking config state... failed |
select model info Quote:
Serial : 0x8da1d261
MODEL_ID : 0x0000
OEM PK HASH : 0x57158eaf1814d78fd2b3105ece4db18a817a08ac664a5782 a925f3ff8403d39a can not find loader file! | info other tools Quote:
Checking for existing devices...Not Found
Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable.
Some phones may need Special Boot Cable or TestPoint for EDL mode.
Found Port : Qualcomm HS-USB QDLoader 9008 (COM23)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.3.7
Connecting to phone...OK
Waiting for response...OK
Init Handshake Sequence...OK
Hardware ID : E1A00900 [8953] 00000000
OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B
Initializing Protocol...OK
Using Auto Loader Selection [1]
Preparing Loader...Done
Sending Loader [8953_009]...Done
Executing Loader...OK
Detecting Storage Type...OK
Hardware : 8953, EMMC, 16 GB
LU Count : 3 [0x01D5A000] [0x00002000] [0x00002000]
WARNING! High Speed Driver is not installed.
Please install driver from QcFire\Drivers folder using Device Manager.
Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512
Reading Partition Table...OK
Reading Device Information...OK
Device : Xiaomi Redmi 5 [msm8953] [rosy]
Brand : Xiaomi
Prod.Name : rosy
Software : CUSTOMER_VERSION_rosy, V11.0.2.0.ODAMIXM [Fri Jan 3 19:06:22 WIB 2020]
Android Ver. : 8.1.0
Patch Level : 2019-12-01
USERDATA : Normal
You can use RESET LOCKS to remove Pin/Pattern/Password WITHOUT Data Loss.
Operation Finished.
