Hardware Repair Item Wanted Post here if you are looking for test equipment or service tools. |
12-20-2016, 12:35 | #95 (permalink) |
Freak Poster Join Date: Oct 2011 Location: uf1 b0x land
Member: 1675290 Status: Offline Thanks Meter: 177 | e2353 aqua hang logo change emmc done by ufi box only 1. back up TA/modem1st/modem2st/modem/persist 2. write kmq72 with full dump extcsd/boot1/boot2/userarea 8gb 3. use user partition menu write all backup no.1 4. replace emmc 5. done Ufi box just make regular to advance technician |
The Following 2 Users Say Thank You to bagus.dps For This Useful Post: |
12-20-2016, 12:44 | #96 (permalink) |
Member: 1675290 Status: Offline Thanks Meter: 177 | N7100 Upgrade internal emmc to 32gb done by ufi box 1. backup extcsd/boot1/boot2/userarea 512mb 2. write it to emcp KMV2W 3. replace emcp 4. flash with 4 files firmware 5. done it so easy isnt it ? |
12-20-2016, 13:06 | #98 (permalink) |
Member: 1675290 Status: Offline Thanks Meter: 177 | oppo R831 dead repair change emcp to KMKJS 1. write kmkjs with factory image mediatek ( scatter file ) and follow instruction you must change config and cid automatic guide by tool 2. replace emcp 3. done just 3 step then permanent fixed |
The Following User Says Thank You to bagus.dps For This Useful Post: |
12-26-2016, 16:28 | #100 (permalink) | |
No Life Poster Join Date: Dec 2003 Location: BiH
Member: 45427 Status: Offline Thanks Meter: 141 | profitability ??? Quote:
This is lot of work. How much you can charge for this from customer? I just curious, because phone like M4 aqua, used is 100-130EU. BR | |
The Following User Says Thank You to bhgsmservis For This Useful Post: |
12-26-2016, 22:35 | #101 (permalink) |
Registered User Join Date: Feb 2012 Location: swimming
Member: 1725884 Status: Offline Sonork: swimming Thanks Meter: 293 | no doubt ufi box is the best tool... Repair dead boot samsung j700h done by ufi box.... |
The Following User Says Thank You to abo anas zayan For This Useful Post: |
01-07-2017, 20:55 | #104 (permalink) | |
Member: 1725884 Status: Offline Sonork: swimming Thanks Meter: 293 | Quote:
1-detect emmc info then you will know version which was on phone like 5.1.1 or 6.0.1 2-then go to factory img select firmware tar or md5,pit-bootloader-ap then flash on emmc tool 3-done flash phone enter download mode flash with odin... | |
The Following 4 Users Say Thank You to abo anas zayan For This Useful Post: |
01-12-2017, 17:09 | #105 (permalink) |
Member: 1675290 Status: Offline Thanks Meter: 177 | thanks alot . dont forget try to backup ext csd boot1 boot2 userarea 256mb if next day you facing same type with full death emmc |
