Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Repair Item Wanted
Hardware Repair Item Wanted Post here if you are looking for test equipment or service tools.
Old 05-09-2023, 10:31   #1 (permalink)
Member: 1346931
Thanks Meter: 3
Samsung A12 no display after factory restore
Hello i have an a12 samsung ...phone is in working conditon but when i factory retore it may gone black no display and light on screen but phone is in working without display phone give sound on charging need help .....?
The Following User Says Thank You to moonmalik For This Useful Post:
Old 05-09-2023, 16:04   #2 (permalink)
abdaouicom's Avatar
Member: 236295
Thanks Meter: 38
Yes, this can work! For rebooting your Samsung Galaxy A12 device, Press the Power button along with the home and Volume Up/Down buttons to trigger a forced reboot
HardReset.info:
There are a few potential causes for a black screen on a SAMSUNG Galaxy A12, and several potential solutions you can try. Here are some things to try:
Restart your phone: This is often the simplest and quickest solution for a black screen issue. Press and hold the power button until the device turns off, then turn it back on again.
Charge your phone: If the battery is completely drained, the screen may appear black even when the phone is turned on. Charge your phone for at least 30 minutes before trying to turn it on again.
Check for software updates: Outdated software can sometimes cause display issues. Check for updates and install any available updates to see if that fixes the problem.
Check for physical damage: If the screen is physically damaged, it may appear black. This could be due to a crack in the screen, water damage, or other types of damage. If you suspect physical damage is the cause, you may need to get the screen repaired or replaced
The Following 2 Users Say Thank You to abdaouicom For This Useful Post:
Old 05-11-2023, 21:53   #3 (permalink)
Member: 1518232
Sonork: Nguemtel
Thanks Meter: 12
hello bro, just change the screen with original samsung A12 screen and your problem will be solve
The Following 2 Users Say Thank You to Nguemtel For This Useful Post:
Old 05-12-2023, 23:09   #4 (permalink)
Member: 1346931
Thanks Meter: 3
A12 samsung
yes i rebot my phone and chargit about 4 to 5 hour ... also remove battery and connect it again but same problem i also try new lcd but still no display on new and old lcd all this happen when i factory restore it before that phone will working perfect but its power key not working properly now phone has no display and light but it give sound when i plug charger.
Old 05-14-2023, 07:30   #5 (permalink)
Crazy Poster
Member: 831155
Thanks Meter: 10
The Following User Says Thank You to maryl For This Useful Post:
Old 05-16-2023, 12:36   #6 (permalink)
Member: 1346931
Thanks Meter: 3
yes it give sound on charging
Old 05-21-2023, 13:49   #7 (permalink)
Crazy Poster
Member: 831155
Thanks Meter: 10
press the Power button along with the home and Volume Up/Down buttons or check the lcd
Old 05-27-2023, 07:59   #8 (permalink)
Member: 2253192
Thanks Meter: 47
try disconnect the battery
The Following User Says Thank You to Remlig For This Useful Post:
Old 05-29-2023, 07:39   #9 (permalink)
Member: 3039020
Hi, Try full restore
Old 06-20-2023, 12:15   #10 (permalink)
Member: 515940
Thanks Meter: 29
BRO TRY THIS SOLUTION
https://www.youtube.com/watch?v=BNxx9dV2Ljw
bR//
SAINI
The Following User Says Thank You to khudda1234 For This Useful Post:
Old 09-25-2023, 23:12   #11 (permalink)
Member: 2702093
fpc maybe., resolder or change it
Page generated in 0.17681 seconds with 8 queries
