BE4 Repair by soft ??? Does it work ? Hi, Has anyone tested repairing BE4 by software, If the problem is no network after bad flash, how to repair (the name of the soft plz) Regards, <br /> <img src="wink.gif" border="0"> |
Soft: <a href="http://alcatel.prolidi.cz/soft2/BE4repair.ZIP" target="_blank">http://alcatel.prolidi.cz/soft2/BE4repair.ZIP</a> <a href="http://alcatel.prolidi.cz/navod.html#n10" target="_blank">instruction</a> Jarys |
[quote]Originally posted by jarys:<br /><strong>Soft: <a href="http://alcatel.prolidi.cz/soft2/BE4repair.ZIP" target="_blank">http://alcatel.prolidi.cz/soft2/BE4repair.ZIP</a> <a href="http://alcatel.prolidi.cz/navod.html#n10" target="_blank">instruction</a> Jarys</strong><hr></blockquote> Hi to all!<br />The ling don't work!<br />my best regards to all<br />cosmo |
http://xak.ipc.ru/gsm/alcatel_be4-5_flasher.gif <a href="http://xak.ipc.ru/gsm/be4-5fl.zip" target="_blank">Download it! / 50$ per copy ;-) /</a> |
Hi Jarys, what is the pass to extract the files?<br />regards,<br />Alro |
To Xak, Is it only a flasher ?<br />Or a repairer, Don't you have any user guide to let us know that ? |
Only flasher as you can see. |
Hi,guys.It is my first variant of flasher for Alcatels.It has lot of bugs-can't read write flashes more than 2 Mb,can't write Intel and Micron flashes,so please don't use it as it <br />was made only for experiments.<br />If you want improved version v1.4 without bugs-I can sell it, just for funny, for 10$ |
HI!<br />where can I find a good prog who repair be4 phones! That from Emsi is not working all the time!<br />10X<br />my best regards to all<br />cosmo |
[quote]Originally posted by alro:<br /><strong>Hi Jarys, what is the pass to extract the files?<br />regards,<br />Alro</strong><hr></blockquote> AlcaTools23 |
The same case as COSMO, the repairing sw by emsi doesn't work. Is there any sw that work, otherwise, i'm searching for a sw to write imei on be4 also; <img src="wink.gif" border="0"> |
Guys, as I have written , my prog works only if u have original flash even corrupted, but u need the original. (and need to change the boot loader after making repair.bin) EMSI p.s.: working to find new repair solution |
Hi EMSI<br />I TESTED YOUR SOFT ON VERSION 136 AND WORKED BUT NEVER WORKED FOR VERSION 138 repair138.dat may be is corrupted when the repair.bin is created it has a strange header which differs from alcatel flashes which as usual begins with 18F0 9FE5..etc<br /> other thing all ireas in BE4 flashes are checksum protected when i change a logo and flash the phone it do not powers up and when i replace logos with each other exp wap logo and operator logo the checksum calculated with hex work shop is still the same and the phone worked <br />regards |
I tryed repair with this soft 2xBe4 138,result-> phone don't turn ON. |
You guys are right, the enclosed repair138.dat is really corrupted, u can use any 138 flash instead and rename it. But there is also that CRC problem, so I will have to work a little to rewrite. EMSI |
