catel BE1 16F & 16D & 16c 16B and more after flashing says "CHECK SIM CARD" hi all members i have 100 pcs alcatel be1 series phone some phone problem check sımcard some problem network and more more . how to repair this phones?? i need real solution i try andromedia, minhea. and some soft but result bad.please tellme step and step how to repair or i use which soft ? :mad: :mad: :mad: :mad: :mad: |
HI with minhea it is the best, but if u have BE 1 16F 2mb flash then u will not get network after power up. with minhea after the first flash completes, do not exit program, put a sim card and power up the phone, if the phone shows u insert sim card after couple seconds then that is a good thing cause u will see network bars therefore it means u can recover that phone 100%. now once that happens power off phone reconnect to minhea press any key and it will ask if u wish to try the next file, say yes and it will flash for short while. then test phone again to see if it is ok, if not carry on till 1 of the flash files match your phone and then it will be working fine. reo |
Use Andromeda 5.2 Set Userdefaults |
thanks for info do you have minhea full soft if you have send it to me ? [email protected] |
hi files are too big, i will send u a link instead. or u can download from the afilip website. reo |
mihnea packets solve most of the issues...works better in slower pc's WBR Surej |
you have full link for afilip site ? |
Here |
thanks to all reply maybe i have all soft but don't repair please tell me step and step which software use how to repair :confused: :confused: |
If you didn't succed to repair 16F , you'll have to replace the CPU with one with an older version and then use mihnea's soft . |
i saved many piece with this version with files saved by me from another good phones files have 2m mihnea software didn't make all versions |
If you didn`t try to flash them yet, i mean if you still have original soft in phones do this. u can try to all be1 but specially that wich power on, and those dead be1 who make a bip when u try to power on. Read between FC000 and FFFFF and save this is teh zone. Now put inside a good flash and restore what you have readet. if teh zone is good should wor 100% and is the easyer way. be1 is the first cloned alcatel, and i used this methode long time ago, and u can try with 2Mb flashes too, but i don`t know teh adress mabe u can find B R |
here |
yes, i have same problem for BE1 for Alcatel,(16A EP112),when i power on , it show me 06/01 11:03 ???-??? ,and then when i calling ,that show me service unavaillable.how shall i do? pls help??? |
