@juanaldo CS problem for 3360 is very easy ,as mobile lab has discribed in above post,just read values from a working fone and write down to affected fone . |
thanks very much for info i will test right now and post results here juanaldo:) |
GReat!!!!!!........im thinking about those guyz who has spent thousands of $ for this solution.....and now its free.......heheheh |
Works 100000%%%%%%%%%%%%%%%% THANKS juan aldo |
hi all of us shoud be thankful to paygee for that !!! |
well the phone works but still have a problem the phone goes off after 30 seconds solution idea juanaldo |
hi try changing flash file version thanks |
this is old story with this solution. you donīt need to write flash-file from another phone to do that job. just patch the .ppm file to erase desired area of flash(in this case it erase full flash-rom). e.g(1260): 00000000 A2000000C70000000DC8080117000001 00000010 1BFFFFC2054443543400C30F44435434 00000020 20414C474F524954484D00C90109CA02 00000030 0D0CCB20E4010A440001201F00030000 (original ppm) 00000000 A2000000C70000000DC8080117000001 00000010 1FFFFFC2054443543400C30F44435434 00000020 20414C474F524954484D00C90109CA02 00000030 0D0CCB20E4010A440001201F00030000 (patched ppm) just use your brain a little bit and you will be able to use this solution on other modells as well. regards, |
@paygee don't you think that there are some persons missing in this thread??:D and i think you know better;) @john it had to be done very earlier.............:rolleyes: |
I think is time to speak clear........ how is f****g loosing? How sell TDMA tool? Thereīs NO alternative tool in the market to TDMA technology.......... |
hi calm down guys, no need to fight. thanks*** we all get free solution and enjoy. i have tested it wih 1265 also ,same 1260 flashes r working,i dont have 1220,some1 plz test it & feed back. |
@paygee yes also work on 1220 100% work @john doe u are jenious ur solution is perfect and short but why u send the post after long time if u find this solution many times before wbr Ahsan Moosani |
1 Attachment(s) HERE IS THE COMPLETE STEP BY STEP SOLUTION TO REPAIR DEAD/NAM LOCKED/CONTACT SERVICE NOKIA 1260 and 1220 1-RUN Griffin v2.07 and select "Manual Mode" 2-Select MCU "nkw1_p06.00f" download from HERE 3-Select PPM "nkw1_p06.00a" Its patched PPM u can downlaod from HERE 4-Press "FLASH" after Flash your phone will be power on but show contact service. 5-Press "Serial" 6-Select from Features: "Important PPM values" 7-Press "LoadFile" and select "1260_1220.pm" u can found that file HERE 8-And NOW PRESS "Write to phone" and YOUR DEAD / NAM LOCKED 1260/1220 will work again with out any problem.. and U don't need to flash 3360 flash file first. This will be most help for the ppl who have phones In quantity like My FRIEND "MOBILE LAP Zubair" "M0OSANI" and MEEEEE... ZAHID and MAKHDOOM in LAHORE.. Best Regards, Wahab PS: I patched that files from solution by John_Doe ALL REQUIRED FLASH FILES ARE AVAILABLE AT MY WEB SITE. www.gsmexperts.com/soft |
HERE IS THE LINK FOR ALL MY FRIENDS.. who want and don't have flash files for NOKIA 1260.. Always ask me to send me plz send me plz. so now ALL SOLUTION IS OUT FOR ALL... check HERE tooo http://www.gsmexperts.com/soft/nokia_1260.htm Best Regards, Wahab |
WHO IS MISSING... can you say the NAME plz. |
