haier c 2000 usb device not recognised haier c2000 shows usb device not recognised as i attache to computer, can any body gives me pinout for this model |
are you using cable in front of cpu........ Br. Shashank |
using cable back said..... |
cheak usb cable & ur charging jeak clean ya change ur problam 100% solve tested me Hariom |
i have replace the jack and also used back USb But Problem is still the same pls do something or tell me pinouts for this model??????? |
use small cable for good resultes......long cables fase some problems |
i have tried with 20 of cables,short and long and medium also, but problem remains same. "pls do something 4 for me" thanx in advance. |
brother no solution for this problem.dont waste time.i face this problem some time |
use card reader ya original v3i cable ok Hariom |
so if u have checked everything now its turn to reflow cpu or flash surely set will be detected on usb br, |
yes mr ak singh is right this is hardwer problem |
tanx to all ,my problem has been solved now by heating cpu |
