Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Various CDMA/TDMA Cell Phones
Various CDMA/TDMA Cell Phones All CDMA & TDMA Cell Phones Related Threads are here
Old 11-18-2008, 06:12   #1 (permalink)
sanjubhai's Avatar
Member: 386868
Thanks Meter: 125
haier c1000 big problem plz help.
i have a haier c1000 set phone is showing phone locked please contact service center, i flashed it with the latest dump flashfile but the flashing stops when the progress bar is on 85%, and the set remains in the same condition, all respected senior members kindly help me to remove this fault,
thx.
Old 11-18-2008, 06:20   #2 (permalink)
~AKSingh~'s Avatar
Member: 65063
Thanks Meter: 2,420
use rx tx ground from a usb to serial profilic cable like moto 261
wbr
Old 11-18-2008, 06:22   #3 (permalink)
sanjubhai's Avatar
Member: 386868
Thanks Meter: 125
i tried it sir but the problem is still same, no progress.
Old 11-20-2008, 06:03   #4 (permalink)
Member: 647758
Thanks Meter: 6
thx.
Dear flash pohe in emergency mode Your phone will ok
Regard By DanishSoft
Old 11-20-2008, 06:53   #5 (permalink)
Registered User
Member: 244875
Thanks Meter: 4
use infinity open wire for flashing check out rx tx gnd or vcc if u facing any problem then contact me on my yahoo id [email protected]
Old 11-20-2008, 10:47   #6 (permalink)
sanjubhai's Avatar
Member: 386868
Thanks Meter: 125
can you please tell me that how to flash it in emergency mode .
Old 11-30-2008, 12:13   #7 (permalink)
neetika99's Avatar
Member: 588837
Thanks Meter: 146
also i want to know....how to flash in emergency mode
Old 11-30-2008, 17:20   #8 (permalink)
Member: 566051
Thanks Meter: 105
No requirment emargency mode cause set is same condition.use infinty box with com 1 port 100000% tested by me.If u have any problem contect me on my yahoo id for free solution [email protected].
regard
umesh garg
Old 11-30-2008, 18:57   #9 (permalink)
Registered User
Member: 100376
Sonork: 100.1591842
Thanks Meter: 150
i'm also facing the same problem returned 5 set which stops at 85%. i did same set earlier but after installing fresh copy of windiws not able flash one set the problem which i have noticed is that when it was flashed 100% downloader made backup of nv(temperary file) while now it is not making any of back file i have tried all the above described solution but none of them had made backup of nv (temperary file) & flashig always stops at 85%
if anyone can analyse this problem in above facts then plz. suggest what to do for flashing this sets
Old 12-01-2008, 06:30   #10 (permalink)
neetika99's Avatar
Member: 588837
Thanks Meter: 146
regard
umesh garg
i tried all ...also emergency mode..but 8 out of 10 sett fail at 85% only 2 sett can make full flashing.if its a com problem than y 2 sett r successfull flashed?.........AND PLEASE POST ANY SOLUTION IF U HAVE.... HERE....THAT CAN HELP EVERY ONE
Old 12-01-2008, 07:02   #11 (permalink)
johnysofts's Avatar
Member: 319956
Thanks Meter: 124
c1000 solution
try with these file and downlloader ur problem will be 1000000% solve.
http://www.MegaShare.com/538319
The Following User Says Thank You to johnysofts For This Useful Post:
Old 12-01-2008, 10:19   #12 (permalink)
rehmani's Avatar
Member: 333199
Sonork: may i help u just pm me
Thanks Meter: 2,405
Thumbs up c1000 solution
use these settings with downloader tool and use infinity serial comport .
The Following User Says Thank You to rehmani For This Useful Post:
Old 12-02-2008, 06:24   #13 (permalink)
Registered User
Member: 100376
Sonork: 100.1591842
Thanks Meter: 150
hi,
yesterday i tried one trick which worked for me i flashed two hand sets & all flashed in single try so i thought it worth sharing but i donot have any technical explanation how & why this has done but to confirm the theory i/m asking the forum members
to check wheather this is working for them or not
i have installed d1600 driver after which flashing of the c1000 is completed the downloader,which is posted by computer,is used
if forum member needs i will post
thanks
Old 12-04-2008, 15:08   #14 (permalink)
Registered User
Member: 809406
Thanks Meter: 31
c 1000 surasfully unlock and new sim working
c 1000 surasfully unlock and new sim working use infinty rx tx gnr and vcc and atach batary male female cable use and com 1 flashing 100% ok set my yahoo id [email protected]
Old 12-05-2008, 12:57   #15 (permalink)
ezysuresh's Avatar
Member: 216081
Sonork: 100.1614205
Thanks Meter: 55
backup nv item after 99% failed. plz help
[IMG] code is Off
E250d big problem!!!plz help akash_agrawal60 Samsung Hardware Repair 0 01-23-2009 18:32
v0.915017 closed 5 lock big problem plz help akhtar416786 SETool2 4 01-04-2009 19:18
black Barry 8310 big problem plz help sameenshah123 BlackBerry (RIM) 4 11-20-2008 06:54
Page generated in 0.21026 seconds with 10 queries
