how to program S.E. CDMA A3014S? Hello, Somebody Help Me To Program Sony Ericsson A3014s Cdma From Japan?, I Need To Change Min, Sid, Etc... Thanks In Advance |
Usually to enter NAM prog in SE phones you use the following sequence >*<<*<* Do you have the SPC? otherwise is going to be near to imposible to reprogram the phone, actually if Im not wrong the only program that can handle that phone is EMMA II which is a SonyEricsson app use a dongle and cost about $5,000.00 If you have the SPC try to change the roaming settings, if you are able to get any local provider you are in luck, otherwise you need to load a new PRL to the phone. |
what do u have emma dll for this phone, i have emma 2 pst crack |
Are you able to connect to the EMMA II server? I also have EMMA II and crack but mine can't connect to the server. |
SonyEricsson A3014S Hi~ Can anyone advises me and guides me thru the below problems? As I know the CDMA system using by AU KDDI in Japan and China Unicom are the same CDMA2000 1x (800Mhz), and my S.E. A3014S is from AU KDDI. Questions: 1) Is it possible to use the mobile service with that A3014S in China Unicom? 2) Is it possible to change the compability of A3014S to fit other CDMA2000 1x systems? 3) What do I need, the methods and how to change regarding to question 2? Your prompt reply is highly appreciated. Thanks guys! |
