new problem in rd3500[lg] i have a lg-rd3500 blinking position i flash to orignal bin [emergency flashing] flashing ok i try to scr or prl prl is write ok when i write scr then 46% set is restart i try to lg tool or lg downlode but same problem so i reqwest to all member plz sere my problem |
try org file (bin & scr) use rd 3500 than post result secend time flashing use usb cable ok ur set 100% ok Hariom |
u see read carefull my post i write that [i flash to orignal bin [emergency flashing] flashing ok ] |
browse scr file click refurbish infact it will not refurbish > the scr will be loaded successfully br, |
Thank for reply cdma master [ak singh] i try also this but same problem acchully phone is come restart position i flash emergency mode with lg tool phone is ok then connect to usb cabel write scr when scr write 46% set is restart and no write scr file then i try to old or new lg downlode referbish and try to your methed but problem is same so at last result this is hardwer problem its flash chip problem i think |
No matter u flash it with og bin or unlocked bin just replace all files with fresh files , sure the scr file infected with virus . i am sure its the perfect solution |
extract all the files n do the job just flash yours set in emergency mode only selecting bin and dll files with help of rj-45 cable write scr and prl* file with ca-101 cable. nothing more then this to say (* = rename it to rim.prl and place it in some other way and use it in LGTOOL) (NOTE = ALL OPERATION SHOULD BE DONE BY LGTOOL FOR BETTER RESULT) |
this is not a software this is hardware reball modem ic 100000000000000000001% tested........................ |
can anyone tell me how to conect cable rj 45 (rx,tx ) please help me i have one 3500 witch can not connect with pc (i flashed wronge hile so) so please give information about emergincy flashing thanking you Patel telecom |
remove bat open set teke board out put cable and slightly twist the board try and post result |
but sir i don't know were is rx,tx point so please upload picture of rx tx if possible your thankfully Patel telecom |
Click here to download pinout picture and post the result BR GSMDHARAN |
Thank you sir i will try than post result |
Thank you very much your picture working patel telecom |
